Question about Yamaha Dtxpress Iv Special Electronic Drum Set
I need to reset ( Factory settings) my Yamaha DTEXPRESS IV drum kit. Erase all input and bring it back to factory setting. Is that possible? Many thanks P.
    President:
  • 1,137 Answers
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
Posted on Nov 16, 2010
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
Sep 17, 2012 | Yamaha Dtxpress Iv Special Electronic Drum...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Apr 03, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Midi Output
If you only have a stereo output from the DT you need to record audio to a sequencer track so you can remix it better.
Dec 10, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
One of my cymbals just stop working, i've unplugged it from the cymbal, turned the amp off and on, restarted the system and nothing seems to be working. I did unplug it from the "brain" i believe, (i just...
Try these:
- change the interconnection cable between the cymbal and the "brain" unit, if the problem goes away, you have a bad cable.
- if the problem persists, see if that particular cymbal works well on another input of the "brain" unit, if it does, you have a problem with the input on the "brain unit", this will require servicing if the unit still has a warranty, otherwise you should first check the solder contacts on the input that doesn't work (also check for dirt /oxydation on the plug contacts and clean if necessary).
- If that particular cymbal won't work when you plug it into any "brain" cymbal inputs (it's basically a piezo trigger so it should work on other inputs), then you have either a broken wire on the piezo trigger or on the cable connector in that cymbal (it should be possible to resolder), or the piezo trigger itself is faulty and needs to be replaced.
I hope you can find out what troubles your drum kit.
regards
3rq8 (triarcuate)
Jul 30, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Add more paths to the drum kit
A line splitter I would asume. Some people just by two brains or more and make a really huge set. I would recomend just buying to brains, alot easyer and more options to chose from.
Dec 15, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
690 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
