Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Same problem I have no capasitors that the tops are bulding at least they don't look like they are. thank you for trying to help I thought since there is a lot people with the same problem someone could were on the board would be the capasitors i need to replace like C152 and C153 but i dont have those nubers on my board thank very mush
    Guru:
  • 1,342 Answers
You may not even have those capacitors on your board. All boards are coded differently according to whoever manufactured them.
Here's a site with pictures that address's this issue and will give you more insight on this problem.
Posted on Jun 19, 2008
I have an LG front load washer and I can't start the machine, the power button will not respond. I have power to the unit because the interior drum light has stayed on. Any suggestions?
The starting capasitor on the motor could be faulty. If this happens the machine would not start running. A method to check if it is the starting capasitor, is to open up the washing machine covers and once the button is pushed - give the motor a turn by hand to see if it starts running. This should only be done by a qualified person as it is dangerous if you do not know what you are doing.
If the washing machine motor starts running, then the capasitor if faulty and needs to be replaced,
Trust this will help you.
Regards
Andre
Nov 02, 2017 | LG Washing Machines
How to recover deleted movie file from buld in memory kodak easyshare Z710 digital camera
Attached the camera to a computer using the USB cable. The inbuilt memory should then appear as a removable drive.
You can then use photo recovery software to try and undelete the movie
Best free recovery software 10 top programs to get your deleted files...
Sep 18, 2014 | Cameras
I have a Samsung syncmaster 2233ws monitor every time I turn my monitor on it stays on for about 2 to 3 seconds and then it goes black I checked all of the capasitors on the mother board and they all...
I would still lean toward the computer being the issue. A lot of newer monitors will pop up something like "no signal" for 2-3 seconds and then enter power saving mode by default. If your getting at least this for a few seconds I would say the computer isn't working. Please note a computer can still have fans and lights going and still be bad. If you have lights and/or fans going I would start by replacing the power supply on the computer.
The easiest thing to do to narrow a problem down is rule out as much as you can. For the monitor if you have another computer, laptop or a friends laptop hook up the monitor to it and test. Monitor works then you have narrowed your issue to your computer. If the monitor still isn't working (you need to toggle the display generally on laptops [fn + F7] usually) then you know its the monitor.
By the way Samsung generally has a 5 year warranty on monitors.
If you have ruled out the monitor and power supply I would then try the following
  • If you have a dedicated graphics card, remove it and plug monitor into on-board video. If it works you know its the graphics card if it doesn't then it's most likely your motherboard.
  • Also can try completely unplugging the computer (pull power cord for 30 seconds) computers don't really turn all they way off usually they sit in S5 power mode)
  • Can also try pulling (if you have more than 1 stick of ram) pull all but one out and try powering on, repeat for each stick until it works. I have seen bad memory prevent computers from booting
Comment back if you need further assistance
Aug 23, 2011 | Computers & Internet
We have the home cinema system ht-tx500 samsung and we can not turn it on does not want to work at all the red light just keeps flashing wher you switch on
There are two capasitors in the power supply that I have changed with success. They are 2,2uF/50V and are close to one of the cooling ribs on the secondery side of the power. There is no sign of bulges on top, but if you use a hair dreyer or heat gun and heat them up the product will work as normal. If you cool them down it will stop working again. Change them both, in some cases I have installed 4,7uF/50V instead. Use 105C capasitors to make them more robust againt the heat from the cooling rib.
Jul 15, 2011 | Samsung Televison & Video
At first, any time i turn on the machine it gives me blue screen at startup and sometimes on the operating sysem reporting that windows has encounter a serious problem with error codes .but now it shuts...
Open the case - Check the capasitors all of those top should be flat - Most propably there is couple of them which has rounded tops (They have dried and not working correctly)
Replace those capasitors or the whole motherboard
Jan 06, 2011 | HP Compaq d530 SFF PC Desktop
While i am try to switch on my mobile it displays like local mode or test mode
try to remove the capasitor on top of battery terminal,,remove the 2 capasitor..
Jun 10, 2010 | Nokia 6030 Cellular Phone
Thermostat keeps kicking in and out
if its the thermostat, it turns the compresor on and off, try a higher setting on the thermostat control. if it still does the same, then it might be the capasitor. if you change the capasitor and have the same problem, you might have a bad compresor.
Mar 06, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Need vertical ic replaced and capasitors. do
Don, who says you need the vertical ic replaced? Although you are to the point as to where the problem is. I think the ic is ok. The ic is a 7 or maybe a 9 pin component. In some cases it could be 13 pins. If you are sure where the location is, it is mounted to a large heat sink. I am not real sure of mitsubishi location scheme . If you can find it, most of the time pins 3 and 4 will be shorted. Measure to be sure. I think it is good. Look real close at the pins. They may have rings around them..resolder these making sure not to use to much solder. They should make contacts between pins. Now examine the four or maybe 5 capacitors with corresponding numbers. replace them with exact values. Use High Temp 105 degree ones. If you decide to replace the vertical ic, removed the clip around it. It will be the LA78--- series, cross it with an NTE replacement. see your electronic store for parts.
Jul 07, 2009 | Mitsubishi Televison & Video
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Replace Capasitors
Just start removing all the visible screws , The power module with the bad capacitors is the unit in the center , Wasn't rocket science to find it either , Just follow where the power cord connection at the tv goes to which board
Jul 13, 2008 | Polaroid FLM-2601 Television
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
