Question about Toshiba Satellite A205-S5804 Notebook
My girlfriend has a PSAF3U-0NR00V Toshiba laptop and the monitor gave out. Any way to get a replacement without buying a whole computer?
  • 2,296 Answers
Yes, you can change just the LCD screen. In this case, for Toshiba PSAF3U-0NR00V Satellite A205-S5804 you need part number V000061680 which ranges around $150.
Here is a parts seller for reference: http://www.sparepartswarehouse.com/part.aspx?partnumber=V000061680&mfg=OEM&sdevicetype=Laptop
Posted on Nov 15, 2010
Toshia PSAF3U-0NR00V wont stay on turns on and off
check for a damaged power connection to the motherboard.
for mine it was the power connection, brought a new one took it apart and soldered it, been working ever since
Jul 20, 2012 | Toshiba Satellite A205-S5804 Notebook
I have a Toshiba PSAF3U-0NR00V, every time i plug the charger to the laptop it goes off, but comes on without the charger, it would charge the laptop,when it's turned off but if i try turning it on...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 23, 2011 | Toshiba Satellite A205-S5804 Notebook
My toshiba model # psaf3u-0nr00v, No power
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | Toshiba Satellite A205-S5804 Notebook
Can you give a site Whre can I download drivers for Toshiba PSAF3U- 0NR00V
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jul 31, 2010 | Toshiba Satellite A205-S5804 Notebook
I cant remember my master password so my computer wont start up. i dont know how it happened but when i turn it on it asks for a password before it boots up. its a toshiba satellite model number...
You can remove a BIOS password by removing the CMOS battery for about 1/2 hour. Find a manual on your system to help, if you don't know where it is.
This is a known issue with some newer Toshiba laptops. The laptop can set the BIOS password on its own and I believe it happens because of a glitch in the BIOS.
Be sure to go to the Toshiba website and get all the updates for your model, once you're back in.
Feb 14, 2010 | Computers & Internet
Download driver for Toshiba PSAF3U-0NR00V Satellite A205
  • Hi, if there are any "Drivers" missing, software out of date, or security need to be updated? You can do the following; If you have "Windows Update" on the Desktop, click to do a scan for "updates" or go to the Start Menu, click on the button, click on ("All Programs") find: Windows Updates, and start a (check for updates). To go further, in the Start Menu; Type: Toshiba Resources, you can also download "Drivers" from this source, in the search Description, type: Toshiba PSAF3U-0NR00V Satellite A205. "Did this solution help?"
Feb 02, 2010 | Toshiba Satellite A205-S5804 Notebook
Strange problem. psaf3u-0nr00v Toshiba Satelite A205 not sure if it was dropped or what. I have taken it apart and reseated everything. Upon depressing the power button the blue light for power comes one,...
okay, pull the ram, hard drive and cd/dvd rom out. then power up the unit. see if you get a bios screen. if you do. then good. let it keep going till it says No Operating System Found. it might even beep and tell you Ram has changed press f2 to resume. go ahead. then reseat your ram one stick at a time and continue this process. in the event you reach a spot where you get the reboot issue stop and back up. whatever you added is the problem. if you get everything working correctly and you tap f2 or esc to reach your bios screen and in the bios everything is happy. then the next step is to verify if your hard drive has crashed physically or just has a hiccup in the software. in the bios there should be a hard drive test run it. it may take 2 hrs but thats fine it will let you know if the drive is bad. in the event it passes fine, then boot again and tap f8 till you get to the screen to load into safe mode. if you can get into safe mode good. from there click MY COMPUTER, right click select properties on that. go to tools and select disk check. select both checkboxes and restart your unit. allow it to run and move bad clusters to clean areas. if you are up and running GREAT! if not, you may need to replace the drive and request your Restore disks if you dont already have them
GOOD LUCK!
Ruben
Jul 19, 2009 | Toshiba Satellite A205-S5804 Notebook
My PSAF3u-0nR00V willnot boot it is a sudden and recent problem
Easiest thing to do is to try and boot into safe mode with command prompt and then run a repair.
Here's a guide.
Jun 13, 2009 | Toshiba Satellite A205-S5804 Notebook
AMar shah
Do you want the drivers for a Toshiba laptop or a dell 1505. Kindly mention the excat model number of the laptop so that we can help you better .
Thanks
proton
Nov 08, 2008 | Dell Inspiron™ E1505 PC Notebook
Toshiba Satellite A205-S5804 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
