Wavy picture after hooking up component switch
I only have one 1081i component input on tv. It was working fine with just HD cable hooked up. I got a PS3 so I had to buy a component switch to hook both up at same time. Now when I watch HD cable or a Blu Ray through the PS3 the bottom quarter of the screen goes "wavy" at certain parts of the show or movie. I notice it mostly when a scene switches or there are some sort of graphics that pop up on the screen. The kicker is that when I play a game on the PS3 there are no problems at all. I have tried switching the cables and trying different jacks on component switch. Any suggestions?
    Genius:
  • Televison & ... Master
  • 1,689 Answers
What you are using is probably an active switch. Many of the movies have macrovision protection. The active switch is having problems to deal with sync pulses from the video containing the macro vision protection.
Jerry G.
Posted on Jun 19, 2008
I can't figure out how to program cable box. The cable is hooked up to the TV, but I can't find out how to get channels. Is there a certain menu or imput?
Are you getting any picture at all? check your tv's input button on the remote if your cable box is hooked up with hdmi select hdmi, if it is component video cable select component video, and if it uses a coaxial cable it should be something along the lines of tv. Push the input button on the remote to switch between the different modes
Mar 20, 2011 | JVC HD-56FN97 56" Television
Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Dec 09, 2009 | Onkyo TX-SR606 Receiver
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
