Question about Sansui Televison & Video
My sansui tv have problem. Transistor c 4460 get short. After replace it, nw fuse blown as supply connect.
  • The Knight
    The Knight Nov 15, 2010
    Hello
    In which section C4460 used in Sansui set. Sasui has circuits with C4460 used in both horizonatal output, and power switching section. You haven't mentioned the model number. Please claryfy, in which section it is used in your TV . Ok
Replace the whole power unit to be on the safe side
Posted on Aug 15, 2013
2 Suggested Answers
tecnic
  • 3 Answers
SOURCE: blown or damaged transistor
I recommend to you to take it to a center of service, since sometimes there are damaged more parts than those who see seen wing although if you himself want to do it then, that I number of part is to give you another suggestion of the possible parts that are damaged
Posted on Mar 01, 2008
My sansui tv have a problem.transister 4460 getting short after replace output voltage drop stand by realese
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 30, 2014 | Televison & Video
Fuse went out
if the fuse in the power supply board was blown, check for shorted component parts like diode and transistor at the power supply board before replacing new fuse.
Sep 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My tv is not switching on but the fuse is no blown,power transistor i did change it
check power supply for capacitors that are bulged up on top, they should be flat.
pretty common problem
Apr 11, 2012 | Sansui Televison & Video
My fuse blew in my Samsung 53" Plasma TV. I changed it, but it's blown again? What should I do next?
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Jul 16, 2011 | Televison & Video
My Sony Bravia LCD TV Got 220v Wile It Should Get 110v,And Went Off
hi...if you have plug the TV in 22oV instead of 11V..it automatically blown the fuse..the power supply has this Varistor it will shorted and blown the fuse if detected high voltage....I suggest you replace the fuse and check for any other defective parts in the power supply section....check for bloated capacitors.. shorted power switching transistor... if none TEST RUN..let see if your TV will switch ON...please rate and vote...
Feb 17, 2011 | Televison & Video
No power fuse blown replaced fuse new fuse blown
It shows that there is shorting in the further circuit,check MOV (metal oxide varistor) used for protection in the mains supply,MOV is mounted parallel to the main input supply,if o.k check further bridge rectifier and finally switching device used for SMPS power supply either transistor or STR by replacing the same.
Feb 04, 2011 | Emerson TS1997 19" TV
Keeps on blowing fuse
Hello
If fuse blows off repetedly, it shows that there is a direct short inside the power supply section. You just check the mains rectifier diodes for short. iIf a rectifier stack is used desolder it out and check for short. In some sansui sets, ther is a metal oxide variste connected across the supply line inside directly. It is for line spike suppression and an overvoltage protection. If any of the above appears on the power line, the varistor will get shorted, and the fuse will go out, to prevent further damage to the circuits. Check that varistor for short. Check the resistance across main filter capacitor for any direct short. If it seems shorted, check the switching transistor for collectror to emitter leak, Resolder it out and check. These are the main reasons for blowing fuse. If the switching transistor has got leaked, you must check the entire SMPS control section, especially in case of used zener diodes, before replaceing a new transistor. OK.
If you wants anu further assistance, inform me through Fixya. Ok.
Nov 05, 2010 | SansuiS2746 TV
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
3 A fuse getting blown when TV is switchedON
Shorted Horizontal output this is on a heat sink at back of tv 3 leg transistor.
Feb 26, 2009 | Sansui DTV2760 27" TV
Sansui 3618 tv
that seems to be a 3.15amp fuse. if it blolws then there is a short circuit
Mar 03, 2008 | Televison & Video
Televison & Video Logo
163 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
