Question about Refrigerators
Uneven and reduced cooling frost forming on back wall of freezer
  • keniwe Nov 15, 2010
    The fridge side used to run fine on 3, now i turned it up to 9, and it's not really cold.
    The freezer side has quite a bit of frost on the back wall, and is only freezing the food in the center shelves, not at the top or bottom.
  • 17,970 Answers
Either you've got a leaky door seal, or your defrost timer, heater or thermostat isn't working. If it's the door seal (easy to check with a business card, just insert it between the seal and the fridge, if it you can slide it in easily at any point around the door, the seal is loose), then just replace the seal or realign the door to seal properly.
Now the defrost heater. Every now and then, the timer tells the heater that it's time to get to work, while telling the cooling parts to take a break. The timer turns on a heater, usually located in the back panel of the freezer, which warms the panel, which melts the ice, and the melted water drains, through a hose, into the drain pan in the bottom of the fridge. When the cooling unit turns back on, the fan blows air over the pan and the water evaporates.
Everything is wonderful until one component of the "automatic defrost" quits working.
The heater and thermostat both require a continuity test. The motor can often be seen or heard to be moving (if you can hear it, it's ok.
Testing and replacement are not too difficult. (Hey, I've done it) A continuity tester is essential. A multimeter or voltage detector can be helpful. For replacement parts, either call your local appliance parts place, or google your model# and "parts", for example- " A4112030642 parts".
Keep us updated.
Posted on Nov 15, 2010
  • 6,993 Answers
can you rephrase this question. what really is the problem. Cause for the above, you said your have "uneven and reduced cooling frost forming on back wall of freeze". So what happened next?
Bye for now.
My powerpoint fridge freezer model trf 285 ice and frost keeps forming on back wall of fridge even with temp turned up to highest
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 21, 2011 | Refrigerators
Freezer is working, refrigerator is not chilled, fan runs intermittently. Frost is starting to form on the back wall of the freezer. I vacuumed the coils.
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
heatman101
May 18, 2011 | Refrigerators
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26F5A fridge at 50 degrees
You will have a blockage in the ferfigeration system. Its not a big deal, a technician needs to regas the fridge. Make sure he installs a new drier before he pumps gas into the fridge. (When the drier is contaminated, it restricts gas flow). This is what you have with your fridge..
Sep 25, 2009 | Refrigerators
I have an 8 year old side by side refrigerator that is not cooling right. We turned the temp to make it colder and its still not cold like it should be. Also, I'm noticing condensation in my drawers and...
Turn your refrigerator off and remove the back wall inside your freezer section. Use a hair dryer to melt off all the frost and ice. The frost was blocking the flow of air over those cooling coils, resulting in very little cooling. The most likely cause of this condition is burnt out defrost heater(s). It can also be caused by a bad defrost thermostat, air leakage like a door left open a long time or bad gaskets, or a bad defrost control.
Aug 16, 2009 | Refrigerators
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge cools at top and not propwerly at the bottom
Check the back wall of the freezer section for frost buildup. Refrigerator is cooled by air that comes from the freezer section. If the coil is frozen over the air is reduced going to the refrigerator.
Jul 11, 2008 | Smeg Refrigerators
Freezer is working fine,but fridge is not cold enough
Check the back wall of the freezer for frost build-up which would indicate a defrost system problem which would reduce or cut off air for cooling the refrigerator section. Service may be required.
May 18, 2008 | GE Refrigerators
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
Mar 26, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
