Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch Classix dishwasher SRS43C12GB/23 not draining. Seems to wash fine but can not pump water out. The pipe is clear, i have already checked. How do i open the machine and check if the pump is blocked?
2 Suggested Answers
  • 98 Answers
SOURCE: 4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Posted on Jul 26, 2009
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Water is not flowing into the dishwasher. Initial problem was that it was not draining. It now drains but now it will not pump any water into the dish washer.
I have this same problem! Just started happening. My Bosch drains fine but only a very little water is entering the unit and it seems to be coming thru the arms on the bottom not the top. Help! I checked the arms and they are clear, drain is clean.
Apr 16, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Water doesn not drain out
The problem is most likely that there is still water residue at the bottom of your machine.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the drain pipe is not kinked or caught somewhere.
Feb 17, 2011 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Water not draining after wash. Checked the troubleshooting guide and none apply to problem. It seems like the pump isn't running.
Have you purchased a new food waste disposer for the kitchen sink area? If so, make certain if you are draining the dishwasher directly into the food waste disposer, that you have removed the plug from the food disposer. Or you may be correct that the water pump is inoperable due to an obstruction or basic malfunction. Contact an appliance service company.
Apr 14, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Jul 26, 2009 | Bosch Dishwashers
Bosch SMS6032GB/20 worked fine the first time but does not pump water inside hence the dishwasher stops. There is 1/4 water already inside on the left hand side.
TRy filling it with the sprayer from the kitchen sink . If it washes properly this way, look at the fill valve and the float assembly. Bosch uses a seperate pump for wash and drain. See if it can drain after the test.
Jul 02, 2008 | Bosch Dishwashers
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
160 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
