Fittef what I pressume to be 2 new imaging units to my Bizhub C350 and a malfunction code has appeared C-001A can you tell me what the problem could be?
  • 1,110 Answers
Sounds like one of the units may be bad as the C001A code means that the Color Imaging Unit drive motor is not turning. It would make sense that if you got this code immediately after changing an imaging unit, that if one was locked up it is now keeping the motor from turning and thus generating the code. In any case the C001A code means the color imaging unit drive motor is not turning.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 15, 2010
How to remove error C0200 on bizhub c350?
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
How to remove error C0200 on Minolta bizhub c350?
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
C-0202
C0202 on a Bizhub C350 means you have a Magenta PC Drum Charge Corona malfunction.
The charge corona is contained in the Magenta Imaging Unit. There are cleaning rods on each Imaging Unit. I would try pulling out the rods and cleaning the wires that way. Concentrate obviously on the Magenta unit. Run it in and out several times. Turn off the MAIN power switch (NOT the one up on the control panel) then back on to reset the code and see if it goes away. If not you may have to have your service company clean the Imaging Unit or it may have to be replaced depending on how bad it is.
Sep 19, 2010 | Minolta C350 Color Printer/Scanner/Copier
Error code for BIZHUB C350 c-001A
The color development motor M6 failure, the DC Power Supply PU1 may be defective.
Feb 10, 2010 | Office Equipment & Supplies
C350 bizhub image unit counter won't reset after changing
using a post:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
thanks for krishmaqvan
Dec 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
My Bizhub C350 has locked due a imaging problem. There are solution without change the imaging unit?
once the machine locks you out for a imaeg unit you are done until the unit is replaced or reset chip is installed but there is new firmware that can be installed in the machine that wil not stop the machine from usage was the image unit has reached end of life so the next time a service tech comes out tell them you want the new firmwareand set image unit life to suspend
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
jasbo
jasbo
