Question about HP DeskJet 812c InkJet Printer
I had walgreens refill my HP black ink container, but when i put it into the printer (HP deskjet 812c), the ink light just flashed continually and the printer won't work...and it makes these jerky sounds, like it's trying to do something (???)...i took the ink out and reput it in, but i finally just shut it the printer off...thx!!!
  • HP Master
  • 3,267 Answers
It may be simply resolved by the following steps
1. there is document in the queue but paper is out
2. Cartridge problem (remove and insert again)
3. Communication error
4. Cover is open
BUT as per your description this seems more apt!!
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON
If its a problem with ink cartridges try these steps
Disconnect the Printer from the Computer.
Press the "Cartridge Change" button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the "OFF" Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn't pushed to the Right so that it goes under the shelf to the "Homed and Locked" Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge's Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn't OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Posted on Nov 15, 2010
Testimonial: "~THANKS!!!!!!!!!!!!!...will check out all your suggestions..........robin"
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
I had my ink cartridges refilled at Walgreens and now the light is blinking on my printer. How do I solve this? I have a deskjet 882C printer
try cleaning the contacts with a towel
if you see no progress one of your cartridge has been damaged due the refilling
check here the right way to refill your cartridge so not to be damaged
http://www.youtube.com/watch?v=TZNoUmS6hts for black
and
http://www.youtube.com/watch?v=5TTFOsGRPJI
for color cartridge
hope i help
pls vote me
May 13, 2010 | HP DeskJet 882c InkJet Printer
Hp deskjet 812c changed both ink cartridges but it will not print
It's Not possible to solve urself, contact service center
Jun 25, 2009 | HP DeskJet 812c InkJet Printer
Hp Deskjet 845c printer's cartridge light blinks constantly.
It probably has, the printer might not detect your cartridges properly, try using new ones
Jun 22, 2009 | HP DeskJet 845c Printer
Hp94c Installed refilled black ink but printer does not recognize
try cleaning the contacts with a wet towel
from both cartridge (black and color) and in the printer
where the cartridges get in (metal pins)
Jun 07, 2009 | HP DeskJet 940c InkJet Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
Hp deskjet 812c ink light blinks w new cartridges
Here write 4 step you do it step by step
1. remove safaty strip from the cartridge
2. clean carridge block contact with soft cloth
3. replace cartridge for short
4. replace carridge block
Feb 27, 2008 | HP DeskJet 812c InkJet Printer
HP DeskJet 812c InkJet Printer Logo
225 people viewed this question
Seeker5211
Seeker5211
