Question about Neff Cooktops
I turn on the hob and it heats up ok then gives an er 13 code and does not come back on, until i turn off and back on at the main switch.
3 Suggested Answers
  • 1462 Answers
SOURCE: Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
MOTORWIZJ
  • 1368 Answers
SOURCE: won't switch on
a hob ??? or am i just stupid ??
Posted on Nov 23, 2011
Induction hob on stand by
it has an electronic brain and clock does it not
Oct 02, 2017 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Won't switch on
Nov 23, 2011 | Bosch Cooktops
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
35 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
