Question about Minolta BIZHUBC351 Color Copier
C 450 NO DISPLAY ON PANEL MACHINE NOT INITIALISED, ONLY POWER PRESNT LED AND RED LIGHT ON START BUTTON BLINK
  • Minolta Master
  • 6,161 Answers
Replace the control panel if not image control board.
Posted on Mar 01, 2015
Have a LG 55ls5700 tv that doesn't turn on but the red standby comes on and when i press the power button it starts to blink
Does the screen quickly blink on and then off? Does the standby light slowly blink twice and then go out?If these are the symptoms then it is probably a bad led backlight strip.This was the fault with my lg 47ln540v led lcd tv.I have written this up in a previous post more comprehensively.Hope this helps..
Mar 19, 2015 | LG 55LS5700 - 55 LED LCD Smart HDTV,...
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Simply blink red light in front or power led light ,no display anything .power on button is on blink red
Try to do a Hard Reset. Disconnect all peripherals connected from the unit (power adapter, monitor, keyboard, etc) then press and hold the power button for around 15 seconds. Plug everything back then power the PC on.
Hope this help. Goodluck!
Mar 28, 2011 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Minolta BIZHUBC351 Color Copier Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
