Question about Belkin Powerline F5D4050 Network Adapter
The adaptor that I plug my PC into has failed. No lights come on. I have tried different sockets but nothing. Any ideas?
  • Belkin Master
  • 7,733 Answers
Reset it!
Posted on Apr 10, 2013
Not getting power at all
check AC - DC adapter could be faulty
Check surge protection if plugged into a surge protected powerboard
Could have a crook powerboard
May 27, 2015 | Computers & Internet
MY HP 6730B will not power on with or without battery installed. the charger light blinks several times but nothing happens. The battery and AC adaptor are only a couple of months old. Any ideas...
Unplug your computer, remove the battery and hold down the start button for 60 seconds. Plug it back in and try to restart. If this works, turn it off again and reinstall the battery.
If this fails, you may have a motherboard issue.
Good luck.
Feb 16, 2015 | HP Compaq 6730b Notebook
My compaq won't turn on and nothing shows that the current is in but the adaptor works properly
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 13, 2013 | Computers & Internet
My dv7 1245 dx had a short at the ac110 adaptor plug on the 18.5 volt end. This shut my computer down. Twisted wires. I bought a new HP adaptor. The computer will not power up now. The only sigh of life...
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
Dec 04, 2010 | HP Pavilion dv7-1245dx Notebook
I plug the ac adapter in, the light will not come on, no matter which way I move it, I just got a new adapter a few months ago.
First try in a different wall socket.. Then check if there is nay damage in the port or if the port is loose were you connect the adaptor.. if there is any damage then the issue is with the system.. Take it to a local tech.. if you have a alternate adaptor check with that.. check the adaptor with your friends computers... Replace the adaptor id its defective.. If you are not very sur about the problem then take it to a loca tech
Nov 02, 2010 | HP Pavilion dv7-1132nr Notebook PC
Dont have a plug for my sanyo eceltric rice cooker
try going to there web site and ordering it,, or go to the store where it was purchased,
May 30, 2009 | Sanyo Kitchen Appliances - Others
Defintely getting power, but not switching on.
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Jun 19, 2008 | IBM ThinkPad T40 2373 Notebook
Power Problem
Try putting the battery back in and start the laptop without the power supply, then, with it running , plug the power supply in and see if the light comes on.
Mar 13, 2008 | HP Pavilion zd8000 Notebook
Belkin Powerline F5D4050 Network Adapter Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
