  • 1,512 Answers
Where abouts in the world are you?
Posted on Jun 19, 2008
My microwave oven works, but the turntable stopped turning. How can I repair this?
turntables are turned by a rubber belt from a small motor
have an appliance service center check it out and get a quote
Dec 24, 2015 | LG Microwave Ovens
Will a ring mat go on my project carbon turn table or will I have to alter the tone arm hight.
There's usually a big enough gap between the stylus and record anyway, before it sits down on one. So I shouldn't imagine that it will increase it that much.
The Ringmat people do however says this:
"In the case of those few turntables that normally have an extremely thin rubber or felt mat and have no tonearm height adjustment, it is recommended that the new Anniversary Gold Spot "Real Ale" version, Anniversary 330 or 330 MkII XLR should be chosen. Accordingly, Linn, Roksan, Rega and similar turntables should use one of the aforementioned Ringmats. If in doubt consult your supplier or Ringmat Developments as to which thickness you require for your turntable."
Feb 01, 2015 | Project Audio Players & Recorders
Turntable stopped working. What should I do?
The turntable motor has become defective and must be replaced, since high voltage is a danger, I recommend a suitable professional for the job and because it is a tricky repair.
Jun 20, 2011 | Magic Chef CHEF9 Microwave Oven
Re: Technics HD51 home stereo system (amp, tuner, CD, and cassette player) - I'm told it needs a pre-amp in order to get any reasonable amount of sound out of lp's on the Linn Sonex LP12 turntable. At the...
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Aug 10, 2010 | Technics Audio Players & Recorders
My Technics Stereo System HD51: I cannot connect my Linn Sondex LP12 turntable to the HD51 tuner/amp because the LP12 has an earthing wire and the HD51 doesn't seem to have a connection point for it....
I'm not sure if your HD51 has a phono connection (two RCA jacks marked as phono input). In case there is one available you can connect your turntable at these connectors. The earthing wire from your turntable (since HD51 has no screw for connecting this cable) can be connected together with one of the RCA at the outter metal. Alternative you can connect the earthing point at any of the back screws cover of the HD51. There is no way to make damage at any of these connections. Make sure that before connecting your HD51 is powered off. After the connection, check that the volume is at the minimum setting and power on the HD51. Start increasing volume slowly. In case a hum comes from the speakers, the earthing point is loosy or the color around the point that the earthing cableis connected prevents the connection.
Check these and in case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Aug 10, 2010 | Audio Players & Recorders
I'm connecting the turntable to a LINN KLASSIC via a PRO-JECT PHONO BOX & usually it works fine but now I only have sound from one speaker. I believe it's the wire from the Technics as all the other...
The phono lead on the Technics is quite straight forward to replace. It does involve removing the deck base and arm base cover and then a bit of soldering but it's pretty easy.
Look here for a new cord :-
Mar 06, 2010 | Technics SL-1200MK2 Turntable
Most of these are belt driven. You need to uncase the unit and check the belt.
Like anything with high voltage, use good safety practices.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable belt drive keeps slipping off.
I have a Linn LP12. At least in the case of my turntable, that's just how you are supposed to use it (i.e. this is what the manual says). You could get a replacement belt f you like, but I would guess it will not make a difference - that is, I think you do not need a replacement belt.
However, in my case I don't have to be very careful about the start-up push on the turntable, just one tweak to get it rotating at about the right speed is enough in my case.
Mar 10, 2009 | Thorens Audio Players & Recorders
Numark TTX Turntable
Just so you know, there is no actual 'motor' driving the platter. It's a direct drive unit, so it's made up of various circuits driving the unit.
With that said, anyone of those circuits could have gone bad. The good thing, is that most of the circuits (resistors, IC's, capacitors, diodes, etc), are relatively cheap ($2-10), the bad thing is replacing them, and finding out which ones are faulty. You could usually tell which resistors are burnt or caps are blown, but it's harder to test the IC's without the proper equipment.
This is not a cheap turntable, unless you think $300 is cheap for a turntable. Repair wise, your probably looking at about $80-120 for parts and labor. It's a well build turntable, and I think worth investing in trying to get it repaired. Just make sure you get an estimate before any work is done.
Nov 26, 2007 | Numark TTX Turntable
I have critical safety and disassembly info at my site, linked in my FixYa listing here: You can find handy exploded views and order the motor here:
Jan 09, 2007 | GE JVM1653 Microwave Oven
98 people viewed this question
