Question about Dryers
My kenmore dryer 70 series only blows out cold air now. it's not drying the clothes. is that the heating coil?
  • Dryers Master
  • 2,180 Answers
Not always,next time send the model number,open the door and look around the opening of the dryer and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or similar,if the filter is on top then unplug the dryer and then slide out the dryer,remove the lint filter and the back panel and you'll find all the parts in the rear,if the filter is inside then all your parts are up front,also depending on the model number on some machines there's an even heat board and relays in the top console that can be bad but i don't think you have this,with a meter read out the heater,and all the thermostats on the heater box and check the thermal fuse located on the blower wheel housing,when checking any part you have to remove at least one of the wires or you won't get the right reading,when you find the part that's bad call your parts store,give them the model number,tell what part you found that was bad and they will sell you the correct part,good luck and let me know how you make out
Posted on Nov 15, 2010
  • Sal DeAngelo Dec 14, 2010
    most of the time i check the thermal fuse located on the blower wheel housing,it's white and has two wires coming off of it,if filter is on top it's in the rear,if the filter is inside then all the parts are up front,if the fuse is good then if it's gas look to see if the ignitor is glowing,if it is then you have bad gas coils or a bad gas valve,if it isn't glowing thn you could have a bad sensor or the ignitor is bad.one more thing the ignitor could still be bad if it's glowing,it works by amps,it should have 3.5 amps but if it's glowing most likely it's good,if it's electric then check all the thermostats on the heater box and the heater,when you read the parts out,the dryer should be unpluged,and at least one wire has to be removed from the part you are checking,if all these parts read good then you have a more serious problem with the timer or the motor but usually it's not,it's usually from not cleaning out the dryer and the high limit thermostat or the thermal fuse go,if it's clean then it will be the ignitor if it's gas or the heating element if it's electric,i hope this helps you and points you in the right direction to fix your dryer
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Kenmore Dryer
Your thermostat could have problem and it confused the temporature inside the dryer. You should change the thermostat. To make sure you can use VOM (vol-amp-milimeter) device to check it. If it reads 0, it means OK. If it reads another number, it is faulty and need changing a new one.
Good Luck
Aug 14, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
354 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
