I need toshiba tv modle no 2130xm diagram - Televison & Video
Install dvd to older pioneer tv
Hello
What are modle number of the devices do you want to connect with? Please inform me these details by Fixya comment box.
Feb 29, 2012 | Panasonic Televison & Video
Have a Disney modle tv and need the code for a remote the remote is not working now modle # P1300NTV
Try setting it to cable remote--see manual or check back label for manufacturer's parts and accessories phone number.
May 19, 2010 | Disney 13" TV
The rca is coming on and going off. the modle no.is m27501 &27f50
No way, Jose!
There are no diagrams for those type of TVs unless authorized service. Also, RCA is out of business. Check the power supply for bloated capacitors. If found, replace with one of the same value.
Good Luck,
Alex's TV Service
Feb 17, 2010 | Televison & Video
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba big screen modle # tz50v61 , power light comes on but tv does not , light keeps blinking . when i try to power it up , light comes on and then starts to blink again . tv will not power up . VERY...
that sounds like it could either be a convergence issue, or power supply issue. If you go to the following link and leave them a email with your model number and symptoms they will help you identify which part you need.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Toshiba TZ50V61 50" Rear Projection...
Codes for classic tv
i have urc17-7710r.... i need codes for teac
Nov 09, 2008 | One For All URC4220 Remote Control
Toshiba tv
Is the red light flashing or solid?
If the red light is flashing it is the signal board is bad part number 75001688 $425.00 - $475.00 depending on supplier.
If the red light is solid then you signal cable has come loose or has went bad.
Sep 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
