Question about Samsung Televison & Video
My tv, samsung LE40A456C2D will not turn on with remote or manual. I have only had it for 2 years at most.
3 Suggested Answers
  • 257 Answers
SOURCE: My Samsung 3 series 330 LCD HD T.V wont Turn on
The sensor board may get jamp. Replace it and if the probem is till there, repalce main board.
Posted on Aug 13, 2009
Raditronic
  • 196 Answers
SOURCE: MY SAMSUNG LE40A456C2D KEEPS TURNING ITS SELF OFF THEN ON
First try to change the power tact switch.
Posted on Aug 15, 2012
Samsung BN59-01223A Remote Control
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Feb 15, 2016 | Samsung Televison & Video
Aug 15, 2012 | Televison & Video
What is the code for SAMSUNG tv......or how can I manually get the code
Hi! try these steps.. I hope it helps..
1. Turn on the TV.
2. On the remote control, press and hold SET
until the LED blinks twice, then release SET.
NOTE: The remote control will exit programming if
more than 10 seconds elapse between key presses.
3. Enter the first four-digit code for your TV. If
you perform this procedure correctly, the LED
will blink twice.
NOTE: If the LED emits a long blink, the code is
invalid. Repeat steps 2 through 3 and try entering the
same code again.
4. Aim the remote control at your TV and press
POWER once.The TV should turn off. If it does
not respond, repeat steps 2-3, trying each code
for your brand until you find one that works.
The code for samsung tv are:
Samsung 0060, 0030, 0178, 0019, 0056
Jun 10, 2010 | One For All URC-1050 Remote Control
My samsung tv won't turn on , It just started to
Your Samsung LCD TV needs a new power supply. You can obtain one by part number from sites such as shopjimmy.com, discount-merchant.com or tristatemodule.com.
Apr 26, 2010 | Samsung LN46A650 46 in. LCD HDTV
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Feb 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
Tv wont turn on
disconnect the tv from the wall first for a few minutes,like 15 or 20 and then plug it back,lets see what happen
good luck
caypianan@yahoo.com
Oct 31, 2008 | Samsung HP-T4264 42 in. Plasma HDTV
Samsung LE32R74BDX ...DTV problems
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Oct 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
TV won't turn on
I have the same problem.
Sep 09, 2007 | Samsung DynaFlat TX-P2764 27" TV
Televison & Video Logo
520 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
