Question about FUJIFILM A170 Digital Camera
I have a fujifilm A170 Digital Camera. When i turn it on there is a message that say's 'card error'. I have tried a new card and still same message.........? what to try next?
  • mopeyandmich Nov 15, 2010
    Thankyou, it was a 1 GB Card so i'll try reformating the old one.
  • FUJIFILM Master
  • 19,396 Answers
Hi.
Test the camera using a 2GB memory card. Depending on firmware version the camera will accept only 2GB. Most models accept up to 4GB.
If that is not the problem, try formatting the memory card (try also with old malfunctioning card.
Instructions on how to format the memory card can be found at page 73 on the manual available below.
Here the user manual.
Regards.
Ginko.
Posted on Nov 15, 2010
Need driver for computer
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 22, 2014 | FUJIFILM A170 Digital Camera
Protected card message on screen
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 08, 2014 | FUJIFILM A170 Digital Camera
I have a fuji A170 digital camera i have 256
All of them will work just fine. The main difference is that a larger card will let you take more pictures.
Sep 20, 2013 | FUJIFILM A170 Digital Camera
Card
The car can only go in one direction and flipped right side up. If trying it turned around doesn't help, make sure it is the right card for the camera.
Nov 17, 2012 | FUJIFILM A170 Digital Camera
How can I reset my FUJIFILM A170 Digital Camera to factory settings without turning it on?
Remove the battery for 15 mins. replace the battery then go to the camera's Menu to set the Date & time.
Oct 18, 2012 | FUJIFILM A170 Digital Camera
How do I get the protected card option turned off?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 03, 2011 | FUJIFILM A170 Digital Camera
FUJIFILM A170 Digital Camera will not take photo
check to be certain the battery is holding a charge, is inserted correctly, make sure the SD card is inserted correctly, IF it is holding charge and card is in correctly is the card full? if so empty it. if you have a SD card slot in the computer see if there are photos on the card if you dont have one in your computer and the camera hooks to the computer DONT DO IT! take the card to walmart, walgreens or somewhere they can see if something is on the card. we are trying to see if its a battery problem a card problem or a Camera problem. if the card is good and has no photos then put it in the camera and asuming the menus come up then format the card. try taking photos if this works great if not see if a friend will barrow their card to you to try in your camera make sure again that their card is BLANK otherwise if you have a bad camera it can blank their card too and you are SOL. try online and search for the model and see if you come up with others that have the same problem. read the manual and if you dont have it do a manual search for the camera model.
Jul 22, 2010 | FUJIFILM A170 Digital Camera
FUJIFILM A170 Digital Camera Logo
141 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
