Question about GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
New used refrigerator
Purchased a used GE monogram refrigerator. It was installed this morning. It has been on for 12 hours and the temp. in the fridge is still 44 degrees. The freezer is about 4 degrees. The fridge does not seem cold enough. Should it take this long to get cold? Also, I did not have the ice maker hooked up, but there is a gurgling noise coming from somewhere, almost as if there is water in the lines somewhere and it is trying to make ice. Is the button on the ice maker when in the off position supposed to be the circle or the dash for off? You can contact me at kprior@hearstnp.com.
  • 943 Answers
HI thanks for your question. a fridge takes at least 24 hrs to get cold and cycle give it some time. the gurgling is normal its the freon boiling in the freezer. its normal. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
I have a GE monogram refrigerator model ZFSB26DRSS. Yesterday the freezer stop working (set temperature 0F, reading temp 30 F). In the morning the refrigerator got warm too (set temp: 37 F, reading...
This sounds like the compressor is not running. Causes for this happening on your model can be caused by defective start relay, run capacitor, defective fan motor and defective motherboard. The part number for the motherboard is WR55X10942
The repair is rather complex for most people on your model and I will be glad to go through how to do this if you like. Let me know and I will walk you through the repair, Thanks
Sea Breeze
Apr 09, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge moogram Model# PSB42YSXSS The first time I went to this unit temp freezer was 12 but ref was 58 cleaned out condenser next morning Freezer 0 ref 37 week later fr is 40 ref58 water is leaking from evap...
Hey Rkraft,
i may have answered that question in the comment ya posted on the other Monogram
But now as i think about it how is the frost pattern on it is part of the evap coil covered in ICE (not frost) that could be a sign of a sealed system problem but only if part of the evap coil is iced up and the tube i spoke about on in that other comment isnt frozen
GENE
Oct 15, 2011 | GE Monogram Side by Side Refrigerator
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator Logo
329 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
