Question about HP Scanjet 4470c Flatbed Scanner
Do you have a driver for the scanjet 4470c for windows vista? Best regards, Ron Kempers email adres r.j.m.kempers@chello.nl
coolcat_12
  • 259 Answers
SOURCE: driver for scanjet 4470c on Vista
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Posted on Jan 26, 2009
SOURCE: Need drivers for a hp
I used to work for HP and called one of the technicians there. Unfortunately there really isn't a solution for this. HP doesn't have a driver to run this unit on Vista. They do however have a program to upgrade or trade in this unit for a new one that does run on Vista.
  • 2841 Answers
SOURCE: HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Posted on Nov 10, 2009
fanaudi
  • 1381 Answers
SOURCE: HP does nor offer a Windows 7 driver for HP4470
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably have already done since a long time ago .
Regards
Posted on Jan 04, 2011
fanaudi
  • 1381 Answers
SOURCE: Anyone found driver for WINDOWW 7 & HP scanjet 4470c yet?
The only ways to get scanner 4470c run under W7 are these 3 options :
1° solution one : make sure driver XP ( yes XP ) is correctly installed . Download and install FreeKapture from http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html . Load FreeKapture , clic on Scan and select WIA-Hewlertt-Packard . Scanner will work fine in this mode but if you choose PrecisionScan Pro , program will hang .
In any case , no slides or negative scans possible but the rest works .
2° solution two : if you have XP install disc , you can install a virtual version of XP on your HDD ( http://www.vmware.com/products/player/ )
3° solution three : if you still have XP install disc , partition your HDD and install XP on the new one (http://www.partitionwizard.com/free-partition-manager.html ).
Don't wait for HP to produce compatible drivers for this unit , it's useless . Regards .
Fanaudi .
Posted on Jan 08, 2011
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Cannot connect hp scanjet 4470c to windows 7
There is no driver for this scanner under W7 but I succeeded to make it work this way :
Regards ,
Nov 27, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
I need Windows Vista drivers for scanner hp 4470c. The support product of HP does not have it. Thanks
I checked the HP website - probably just like you did. They do not have drivers for the Scanjet 4470c. Looks like time to get a new scanner... You can list the current model on craigslist - maybe someone would be interested in it themselves.
Sep 23, 2010 | HP Scanjet 4470c Flatbed Scanner
Doesn't work
Scanjet 4470c does'nt work under Vista nor W 7 . No drivers available .
Here are a few hints :
1° hint :
Reboot .
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably allready have .
Regards .
Jul 08, 2010 | HP Scanjet 4470c Flatbed Scanner
Need a hp scanjet 4470c driver for os 10.5.8
Production of HP drivers stops at OS 9 .
No more driver available for further OS .
Regards .
Apr 21, 2010 | HP Scanjet 4470c Flatbed Scanner
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
4470c
If you can get the software on your computer, right click properties and check run in XP mode
Aug 28, 2008 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 4470c Flatbed Scanner Logo
112 people viewed this question
Seeker5211
Seeker5211
