Question about Dell Studio 1537 Laptop
Black screen and overheating - Dell Studio 1537 Laptop
  • 2,296 Answers
To avoid laptop overheating, follow the information from this link.
Posted on Apr 13, 2011
Half the screen is black
The white dots are most likely to be failed pixels in the LCD screen. When the picture elements fail, they switch to clear and what you see as white is the backlighting.
The overheating issue in laptops is generally caused by dust and fluff blocking the cooling fins and ducts or a failed cooling fan, but it could also be caused by a hung process which runs the CPU at a high processing speed. Press control (CTRL) ALT and DEL and look at the task manager and see if you can see any processes that are running constantly near or at 100% to eliminate this being the problem.
The failing display is unlikely to be related to the overheating issue.
Mar 17, 2015 | Microsoft Surface RT
Its a dell model pp37l power on has black screen tried reseating memory even got new memory still has black screen when powers on
usually when you get a black screen on a laptop it has something to do with the graphics processor or the cable connection to the screen or worse its been dropped or overheated the mother board. hope that points you in the right direction
Mar 04, 2015 | Dell Computers & Internet
Black screen even on external monitor
Replace the motherboard. They are not that expensive.
Feb 08, 2014 | Acer Aspire 3680 Laptop
I have installed windows XP on Acer Aspire 4520 and since it was not booting up normally i installed all the drivers in Safe Mode. Even after doing the same it's not starting normally just a blank (Black)...
your computer your laptop will just shut itself down and get a black screen unexpectedly, which is due to: power overload in the AC adapter, overheated processor / clogged fan, overheated battery, pushing the power button, Windows telling it to, the BIOS telling it to, loose wires (especially the power cord), or intermittent short circuits. The most common problem is cooling. the battery should be removed from the laptop and allowed to cool to room temperature before attempting to use again.
Oct 26, 2010 | Acer Aspire 4520-5141 Notebook
I have a Curtis LCD1922A and it comes on and has white screen then goes black
The ballast transformer of the cold cathode on your monitor is overheating.. Replace this..If the monitor is on and keeps on changing from white screen to black. The cold cathode light is almost up. Replace this one too.
Apr 05, 2010 | Curtis CM19033S 19" TV
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Black screen, only two yrs old.
replace the dc fuse in the power supply
same problem person: your power supply is overheating check the fan(s)
Jun 03, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Screen problems/overheating problems
If it's an overheating problem, updates won't help, cooling will. With the unit turned off, blow out all vents & screens on the bottom, sides & back of the unit. Get a cooling unit to put under the laptop. Mine dropped the temperature about 30 degrees and it hasn't shut off since I started using it.
If it's not from overheating, the way you have Vista setup to view different users windows should be changed.
Jan 04, 2009 | Acer Aspire 5100 Notebook
Dell Studio 1537 Laptop Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
