Question about Refrigerators
THE REFIGERATOR IS LEAKING FROM THE BACK and I have never defrosted it. Does this need to be done to this model?
  • 4,793 Answers
Whilst most freezers are frost free,fridges are not,it is a good thing to defrost every 3 months to keep max efficiency,it is also a good excuse to clean it out.
Posted on Nov 15, 2010
Testimonial: "great answer, very helpful"
Refigerator model 253 kenmore leaking water on floor
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 25, 2011 | Refrigerators
Water leaks into the refigerator compartment. The refigerator is about 15-20 yrs old.
Leo Ponder
imufo2
Aug 23, 2011 | KitchenAid Refrigerators
My Whirlpool refigerator, Model ER2CHMXPL02, leaks. Water leaks into the refrigeration compartment, apparently from the freezer compartment above. It does have an ice maker. The water leaks down the...
You have a defrost drain that is plugged.You will need to locate the drain and clean it out.Take off the cover for the light and you may see the drain. If not there then pull the refrigerator out from the wall and you should be able to get to it from there.Hope this helped.
Jun 03, 2011 | Refrigerators
Temperature in a frigidaire refigerator too high model # lgub2642lf2
have you check its thermostat settings? or maybe it is in the defrost mode?
is the compressor running? if it is, most probably that you have a leak in the system. have a technician to repair if this is the case after adjusting the thermostat.
Dec 31, 2010 | Refrigerators
Slightly different model looks the same JFC2087HRS French Door. Refigerator section stops cooling and a 24 hour defrost gets it going again. Problem is I had it fixed for this about a month after I got...
after that many repairs you we can say that it has a defrost problem. the freezer will not defrost it self if off for 24 hr . but if the coil is defrosted then we know that we have a complete defrost . now I would replace the derfost terminator and if the problem came back replace the adapitive defrost control .. now with your history if either has not been replaced the replace both of them and your done . this should correct problem .. mm .. hope this helps .. ****
Oct 07, 2010 | Jenn-Air Pro-Style JFC2089H French Door...
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
Apr 22, 2010 | Refrigerators
The top of my refigerator is freezing in the back
Hi, the problem you are having is the defrost timer not going into defrost mode when the timer says to. They are normally located in the bottom back of the unit and will have a screw driver slot on it. It may be stuck in the off position. Turn it a click with a screwdriver and see if this starts the defrost mode and other problems. Is the evaporator fan in the freezer up and running? If not, this motor must be on. Keep me posted on this and we can get to the bottom of the problem.
Sincerely,
Shastalaker7
Mar 03, 2010 | Refrigerators
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
