Question about Samsung Syncmaster 2033SW Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga cable and put only dvi cable then its showing no analog devices found? i need to use only dvi cable but its not detecting it. pls help me out
    New Friend:
I have the same problem, and this doesn't work for me
Posted on Jan 28, 2013
  • 1,719 Answers
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Posted on Nov 15, 2010
SOURCE:
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
My Samsung SyncMaster 2253LW Monitor can't auto adjust problems
if your using a DVI cable instead of a VGA cable you won't need to auto adjust anything because it is done automatically when using a DVI cable. a DVI cable looks like this and a VGA cable looks like this
Apr 30, 2011 | Samsung SyncMaster 2253LW Monitor
I have a samsung 2033SW monitor which flickers very frequently displaying that "your optimal resolution is 1600x900.Follow the above settings to set".Though I have set the resolution to 1600x900...
- You can test the monitor by using another CPU, if still the same then the problem is monitor, but if it's working well then the problem is your CPU, to make it sure then you can try another monitor on your CPU. - check if the hardware connection is well attach, you can pull & re- plug the hardware just to make sure. - the monitor is need a DVI connection (white or gray) to run properly, if you use AGP connection ( blue ) on your VGA card that might the problem, so you can also try upgrade your VGA card. - other ways is to install the latest driver for your VGA card.
Jan 14, 2011 | Samsung Syncmaster 2033SW Monitor
Syncmaster 2033SW Monitor: I bought my samsung 2033 a month ago. It recently ...
I would take it back right away, when electronics break down in lees than 6 months it is not a good sign. Get the replacement or have it fixed under warranty.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 18, 2010 | Samsung Syncmaster 2033SW Monitor
Need to increase font size without effecting pixel clarity
The first step for optimal readability is to set your PC's graphic output to the native resolution of your monitor.
The Samsung 2033SW is a little unusual in this regard since it provides a matrix of 1600 x 900 pixels, which is not very common.
If your graphics board has DVI output, I'd also make sure to use a DVI cable to connect to the monitor instead of VGA.
Windows XP and above support a font rasterization technology called "ClearType", see http://en.wikipedia.org/wiki/ClearType. This page also provides references to the ClearType tuner PowerToy for XP, which is available to Windows users at no extra charge. Windows 7 has a control panel for ClearType out-of-the-box.
If you still need to increase font size, you can increase it from the Display Control Panel, too, "Medium" font size scales to 125'%, "Large" fonts to 150% the normal size.. Changing the DPI (dots per inch) setting in the monitor control panel cannot be recommended since some software cannot cope with alterations here (dialog boxes or user interfaces with text in wrong places or sticking out of the window... yeeks.)
Feb 07, 2010 | Samsung Syncmaster 2033SW Monitor
Cannot get a picture when using DVI cable on my
Check on the monitor OSD the input settings. I am assuming you're not running both inputs simultaneously some monitors detect that since it is an "either or situation"
in rare circumstances it could be the cable as well. Samsung SyncMaster 226CW Owner Manual
Nov 25, 2017 | Samsung SyncMaster 226CW 22" Monitor
Faulty VGA input
It is uncommon to have a faulty VGA input, although occasionally the pins get bent or broken on the cable. First check the cable.
Have you tried using a different source?
Some graphics cards/computers will only output DVI and VGA separatly and not at the same time. You may have to go into the display settings of your computer and change the output from DVI to VGA.
More details would be great,
Thanks!
Jan 15, 2010 | Samsung SyncMaster 226CW 22" Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Samsung Syncmaster 2033SW Monitor Logo
1,191 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
