Question about Dell Inspiron 1545 Notebook
I have a dell inspiron 1545, it is 15months old and recently the screen started to flicker, and then it went blank, it works on an external monitor and you can see a faint image on the laptop screen (not good enough to actually use), i just wanted to know is this a common problem with Dell's, and what the cause of the problems is? what i really need to know is if the problem is common cause then i can get pc world (the retailer) to fix it!!!
  • 1,719 Answers
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Invertor board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
Rest assure that your system is ok and you can check it by connecting you laptop with some external display, which would work fine.
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
Hope this answers your question!
CreativeTECH
Posted on Nov 15, 2010
  • 734 Answers
HI There,
You almost certaily are experiencing one of only 2 problems. Either your "screen inverter" or your "backlight" has failed. Since you have to expose both the screen and inverter to do the repair, it's always best to replace both the screen inverter and lcd panel at the same time.
Good job on hooking up to the external monitor. That ruled out a failed video card on the motherboard so count your blessings.
This problem is not Dell specific...it happens with all brands of laptops. It's a bit like your car. Things are just going to wear out.
Kind Regards,
Selk
Dell Inspiron 4100 flickering off and on Makes it extremily hard to work with . How can I tell whether it is the display or something else?
What happens when you hook it up to a external monitor? If it works fine with a external monitor, then your laptop monitor is going bad. If it does it with an external monitor, then its more than likely an issue with your laptops video adapter.
Oct 21, 2012 | Dell Inspiron 4100 Notebook
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
Dell Inspiron 9400 laptop display problem
First power the system on using Fn+Power and see if the diags run and you have video. If you have video in the diagnostics, then I'd suspect the video card as the failure point.
Also connect an external monitor and press Fn + F8 to activate the VGA port If you get video on an external monitor, I'd suspect the LCD as the failure point.
Dec 26, 2009 | Dell Inspiron 9400 Notebook
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1501 display almost blank
Try changing the memory stick, if still doesnt work, it means the invertor of the screen is gone.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1545 Notebook Logo
338 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
