Question about Ovens
My oven door will not open . I have a black THERMOR duo oven . It is the main fan oven that is locked after a power failure during heating up of the oven . Thanks
textonor
  • 130 Answers
SOURCE: Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Posted on Jan 06, 2008
SOURCE: Cleaning cycle failure
if it is not a brand new oven, i think the problem is with the top oven while the cleaning cycle the temp is way too hot and possible burned one of the wires above the oven. get that check out. good luck
Posted on Apr 15, 2008
SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Posted on Sep 05, 2008
Tomwillfixit
  • 5 Answers
SOURCE: belling no heat in main oven
You need a new element buy on line much cheaper,
Posted on Oct 04, 2008
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
Bosch hbj 435 Won't heat up clock works fan on when open door
I don't see that model in my listings, but generally this is an out of sequence lock.
CLOSE the oven door.
SET the self cleaning cycle.
WAIT 3½ minutes.
CANCEL the cleaning cycle.
WAIT! WAIT! WAIT, at least 10 minutes and check to see if there's normal operation.
If not, either main board, lock switch, or primary temperature sensor
Apr 03, 2017 | Bosch Ovens
Prestige built in fan oven for no reason keeps tripping the fuse was working good till about a week ago
ISOLATE FROM MAINS SUPPLY BEFORE CARRYING OUT TESTS
Remove oven from unit, remove back visual inspection of wiring, this should take about 30 mins.
Several makes of ovens use heat temp control components, usually mounted on the frame or back of the oven, inspect, if there are signs of heat around the component replace. When oven is switched on is the fan blowing air when the door is open, if not very strong remove fan and clean with WD40, make sure this is dry before fitting again. If fan appears to be working correctly, a heat element could be faulty, inspact when the fan has been removed it should be mounted in front of the fan. If there is black spots, not food build up, it is more grey to black, replace the element, you should be able to get parts from white goods .co.uk. Without more info I am unable to help.
Hope this is helpful
Johnf1
May 17, 2011 | Ovens
Can't open the oven door with an F9 and beeping
Here's the info from the service manual
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
The panel went black- no display of clock, temp, etc. The oven doesn't heat up. the light weorks inside the oven
Hello, and sorry to read about your problem.
if you have tried to re-power the unit, and still have the same issue, you then have a general main board failure,
you may want to contact a service company. it takes experience to know which part is defective.
I tried to help you. Please help me and vote/rate my response thanks.
Jan 01, 2011 | Whirlpool RBD245PD Electric Double Oven
Magic Chef Range - oven door won't open Gas Oven with stove top 1980's Model 64DY-3CKXW all dials/no electronic displays There are two dials for the oven One that controls the temperature and another that...
If a selfclean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Most self cleaning ranges today use one of 3 different types of door locking systems. One design is solenoid driven, another is heat activated and the last, motorized.
  • A solenoid controlled system can be identified by the lever that must be set to lock the door, plus a loud buzzing or clunking noise heard when locking or unlocking the door.
  • The heat sensitive lock mechanism also has a locking lever but makes no noises. It instead utilizes a coiled spring to slowly lock the door as the oven heats.
  • The motorized design has no lever to move, the motor locks the door by itself when the range is set for self clean. The motor may have made an audible whining or ratcheting sound when in use.
A motorized or heat sensitive style lock will usually be located beneath the cook top on free standing ranges. The cook top would usually need to be lifted to access the locking mechanism. On built in ovens, the oven must usually be removed from its enclosure (or at least partially) in order to remove the top panel to gain access to the locking mechanism. On some built in oven models, the lock assembly may be able to be accessed by removing the control console.
sc-lock-geheatsensitive.gifOn the heat sensitive style (illustrated), there are no electrical parts used to operate the lock which could fail, so the whole mechanism will usually need to be replaced if not operational.
With the motorized lock mechanism, a volt/ohm meter is required to try to determine why the locking motor will not operate. The failure could be in the motor itself or the power supply leading to it, including a door activated and/or console mounted switch and switches on the latch mechanism itself.
On solenoid activated designs, the solenoid coil is a common failure point which is often mounted on the back of the range. On many of these models, the lock mechanism can be accessed by removing the rear panel of the appliance. Some models such as built-in ovens or drop-in/slide-in ranges, may have the mechanism mounted towards the front, under the top.
sc-lock-gelocksolenoid.anim.gifFailure of a solenoid style lock is most often caused by a bad solenoid. Once the lock is located, the solenoid coil can be checked for continuity. Some latch assemblies also have micro switches in the power supply that will need to be checked for faults too.
Be certain to unplug or remove power from the range before undertaking any repairs yourself and follow all standard safety precautions.
usually if you are unable to open it after all these tests then you would resort to manually opening the door by getting a piece of wire and slip it where the latch mechanism is and prying to the left this is a last means resort so try these other ways and get back to me with any further questions that you may have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 18, 2010 | Magic Chef Ovens
I self-cleaned our oven yesterday. After waiting
in order to get the door open you can remove the door locking motor and turn the locking shaft.
there could be a problem with the excessive heat from the oven during the cleaning cycle check with frigidaire and see if there is any kind of recall for this problem
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
3. Wiring Problem.
1. Press CLEAR key.
Switch circuits.
P4.
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
