Question about Toshiba Satellite A215-S7407 Notebook
I have a Toshiba Satellite P30-145. On bootup the screen is a flickering red - once windows has loaded, you can see red ghosting. Before replacing the screen, it was red on boot and in windows. I have now replaced the inverter, running out of ideas.
  • 1,719 Answers
The problem could be with the RAM. If you have two RAM Sticks, try using one at a time. Else, try replacing the RAM. I faced this issue a few months back with toshiba and replacing RAM worked.
Hope this works for you as well!
CreativeTECH
Posted on Nov 15, 2010
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
Screen "Flashes" on/off
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 12, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite and the lcd screen keeps ''ghosting'' in fluro green, any idea what's happening and whether i can fix it?
To check if the video card is faulty or the LCD screen.
Connect an external monitor to the laptop's external video port, power up the external monitor first then bootup the laptop. The Windows will automatically switch to the external monitor if the video card is OK. If not then the fault could be the video cable cable/connector or the LCD screen.
Get back to me with the results of this test and I can advise further.
Jul 05, 2009 | Toshiba Computers & Internet
Describe your Toshiba Satellite® L10 PC
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | Toshiba Satellite L10 Notebook
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
LCD Display flickers,then goes dark on bootup
Sounds like your display inverter has gone bad. You should be able to find an inverter for this model or if the computer is still under warranty I would find an authorized repair center for this brand of computer.
Dec 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Screen flickers and then turns gray
Access BIOS and test if the flickering continues.
If not, it is a Software problem, do a full system recovery
If yes, it is a hardware issue, better contact Toshiba tech support to have your LCD repaired if you are still in warranty.
If your not in warranty, you need to check out the LCD harness that might have been loosely connected.
Hope this helps...
May 12, 2008 | Toshiba Satellite A135 Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A215-S7407 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
