Question about TruTech LMD-5702RT Portable DVD Player
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
    Master:
  • TruTech Master
  • 772 Answers
If your DVD player is in trouble of "no disc", you could refer to this tutorial about "How to fix a DVD "No disc" error".
Posted on May 24, 2019
  • 734 Answers
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Posted on Nov 15, 2010
SOURCE:
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
Will not play dvd. Takes disc in says "loading"
firstly is the disc an origional dvd or a copy? most dvd players wont play copies or dvd's made on a pc, also is it a dvd for the region you live in?, failing those , maybe the lens just needs a clean 8)
Sep 08, 2011 | Televison & Video
I tried playing bully and it will say "reading
if thats the only game it does that for i would clean your disc..it does that when there is a bad disc.
Mar 07, 2011 | Sony PlayStation 2 (PS2) Console
I need help with my ps2, its about 4 years old, The bulky model. up until a few days ago, it worked perfectly. yesterday it was a bit glitchy, but a few resets fixed it. Today i wanted to play it, so i...
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Dec 31, 2010 | Sony PlayStation 2 (PS2) Console
PS3 won't play says loading continuously
go to www.modchipman.com and repair sevices i used them when my xbox's were dead and they had the red ring and disc read error they can fix it in ten minutes i watched them install a new tray on mine. anyways they have your problems the disc error and freezing. $9.99 but your yellow light $99.99 the cost to see your ps3 run again.
Sep 12, 2009 | Sony Playstation 3 (PS3) Console
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
When a disc is loaded, it reads no disc, and disc cannot be played.
It is very possible that the lens motor has burnt out. Sometimes the capacitors on the motherborard short out causing the gear timing to go out..
The only thing you can do to fix this is to take the cover off. Get cotton swab and dip it rubbing alcohol and clean the glass laser eye with it.
Jun 03, 2009 | Samsung DVD-HD850 DVD Player
Vcr works but dvd disc of go video solely say loading
There are a few different things that you can try. First make sure that your discs are clean before you put them in the player. Even if the disc is new I would recommend cleaning the disc off. The second thing that you can try is a DVD player reset. You can do this by unplugging the player for about 5-10 minutes. Then plug it back in and try the disc. If that does not help I would try a DVD head cleaner in the player. If all of these things do not work, it is most likely an issue with the player.
the laser inside may be having the problem or the optical sensor inside the player is not proper.....
if after all the above said procedures fail kindly contact ur manufacturer.
thank you
Apr 06, 2009 | GoVideo Go Video DVD/VCR Combo
When I load a DVD into the Samsung player, it says it's loading, about a minute later it states, "...can't display disc, check disc.
hi emiller,you might be playing a format not known or cannot be played on ur dvd player check if any original format (dvd) works on your player.
May 11, 2008 | Televison & Video
TruTech LMD-5702RT Portable DVD Player Logo
625 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
