Question about Fisher and Paykel Washing Machines
I was given a 2nd hand Fisher & Paykel SmartDrive051 washing machine a few months ago but now it is not filling with water or agitating in order to wash the clothes.
  • loz_carey Jun 19, 2008
    Thank you for your advice
If some sort of control and lights on but just doesnt start then lid switch. if beeping instead of start then its found a fault. its well over 10 years old , may not be worth repair
Posted on Jun 19, 2008
My Fisher and Paykel washing machine's lights are flashing. Fault code 65. When I opened the control panel, there was water in there. What do I do?
Grabbing the agitator would not cause error 65. Yes that error can only be solved by replacing the control module. Water can only have come from the filling valves & chamber on the left hand side inside the panel. Completely dry all areas inside the panel, especially around the filling valves & chamber. Put machine on wash cycle & start. While filling, have the control panel open & watch for any water appearing from anywhere. Fix the leak then replace the control board.
Aug 05, 2017 | Fisher and Paykel Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
F & P excellence 6.5 smart drive - Model GW608U - the machine will not fully progress throught the "Rinse" cycle. It will empty the wash water and spin & spray a little, then power...
Hi - this sounds more likely to be a faulty motor control module, its overheating and a electronic component is failing. Only way is to fit a new control module to eliminate the possibilty, another probable cause may well be the RPS sensor failing as it goes into spin mode.
Really need to do a few tests with a multi-meter, see if the motor/stator windings are ok, a faulty RPS at times will give a similar head ache..
May 05, 2011 | Fisher and Paykel Fisher & Paykel Washer
Machine fills and starts to agitate, then stops. Will pump out & spin but not agitate. Refills with way too much water. Continous 1 second beeps. All lights on or 2nd, 3rd & 4th from left. Not...
Hi just read your posting.Could you please confirm the lights that are on when the machine is beeping as the lights you described that are on is not an error code.Also please confirm the model number for me.It is on s sticker at the back of the machine top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
