Question about Sanyo DVW-5000 DVD Player/VCR
Hook up and programming
I lost manual and not sure it is hooked up right. Tried to program channels and that didn't work. Got cable running thru the Sanyo but no response from DVD/VCR. TV works and power c omes on the DVD combo but no blue screen appears just snow. I've tried both Channel 3 & 4 with no change. Help!
  • 4 more comments
  • J-Lady Jun 23, 2008
    No sound. Just snow.
  • J-Lady Jun 25, 2008
    Still nothing but snow and now I can see a faint Sanyo insignia.
    Tried other set of coaxial wires- same result.
  • J-Lady Jun 26, 2008
    Not coaxial, I guess. Made sure it was hooked up color coded and same result-- same snowy faint Sanyo image. No sound or picture. TV working fine.
  • J-Lady Jul 07, 2008
    Tried another TV with same result.
  • J-Lady Jul 09, 2008
    can't be cable problem because my other small TV has built in Dvd/Vhs and it works fine.
    Novelist:
  • 121 Answers
Do you have it plugged in with the coaxial cable or do you have it plugged in with the yellow,red,and white cables? If you arent using the coaxial cable and are using the red,yellow, and white cables make sure they match the color of the ports on the TV and DVD player. So you will want red to go to red, white to go to white, and yellow to go to yellow at both the DVD player and the TV. Also make sure you have the cables connected at the terminals labeled OUT. Same if you are using the coaxial cable. Good luck and keep me posted. Let me know if you have anymore questions. If you found this helpful please rate this solution when you get a chance. Thanks - Tech101
Posted on Jun 26, 2008
  • Justin Jun 26, 2008
    Make sure you select the TV input instead of channel 3 or 4 because since it is not coaxial cable it will not work on channel 3 or 4. Try pressing the TV/Video or TV/Input button on the TV. Let me know if this works. Thanks - Tech101
    Sergeant:
  • 260 Answers
  • plug in a different tv to see if there is a different result
  • plug cable directly into tv to make sure it works (skip dvd)
  • If nothing works after that call the local cable service provider.
Posted on Jun 25, 2008
    Guru:
  • 1,342 Answers
The video cable (coaxial) should go into the dvd player and another one out from the dvd player to the tv. Remote set to dvd player. Instead of channels 3 and 4 look for video 1, video 2, aux or something similar.
Posted on Jun 23, 2008
    Genius:
  • 2,035 Answers
Try yo play a audio disc and check for the sound, unpug the connection and replug the one by one and then check if the display is coming on the TV screen :
For further trouble shooting:
There is no picture.
The playback picture is poor.
Screen size is wrong.
“ ” appears on the TV screen.
TV picture does not appear on the TV
screen.
TV reception worsens after connecting
the unit.
The playback picture or TV program
from the equipment connected
through the unit is distorted.
POSSIBLE CAUSE
The video cable is not connected.
The TV is not set to receive signals from the unit.
No disc is loaded.
“PROGRESSIVE” mode is set.
The disc is dirty.
An unplayable disc is loaded.
Incorrect aspect ratio setup on TV.
Incorrect “TV Display” setting.
The aspect ratio of the disc is fixed on your DVD
The selected function does not operate on the disc
now.
The antenna cable is not connected.
TV channel is not selected.
RF signals are weak.
The program contains copy protection signals that
restricts copying.
CORRECTIVE ACTION
Connect the video cable into the jack.
Select the correct input function on the TV.
Load a disc. See page E45.
Select “INTERLACE” mode. See page E44.
Clean the disc or replace it.
Load a playable or recordable disc. See page E38.
Refer to your TV’s owner manual.
Select the appropriate setting for your TV screen
size. See page E30.
The feature or action cannot be completed at this
time because:
• The operation is prohibited by the unit or the disc.
• The feature is not available at the moment.
• The DVD software restricts it.
• The DVD software doesn’t support the feature
(e.g., angles).
See the antenna connections. See page E8.
• In “NO DISC” mode, (1) press the n button, (2)
press the TV button, (3) and press the CHANNEL
button (+ or -) or press the number buttons on the
remote control.
• Press the INPUT button to select the TV mode.
• Press the TV/DVD button on the remote control to
select the TV mode.
RF signals are being divided between the unit and
the TV. Use a signal booster. Please consult your
A/V dealer.
Disconnect the playback equipment form the unit
and connect it directly to your TV.
Posted on Jun 19, 2008
    Brigadier General:
  • 3,614 Answers
Have you try to check the the video cable connections from the dvd to the tv..?
  • 4 more comments
  • micromaster
    micromaster Jun 19, 2008
  • micromaster
    micromaster Jun 25, 2008
  • micromaster
    it seems that you tv has no cable signal..
  • micromaster
    micromaster Jun 26, 2008
    did you try to connect another working tv on the cable connection..
  • micromaster
    micromaster Jul 08, 2008
    well then, the problem is either on the cable box or in the cable line... it is better to call your cable provider about this..
  • micromaster
    micromaster Jul 09, 2008
    Comment by J-Lady, posted on Jul 07, 2008
    you said this... and there you say it gave you same result when you try another TV...
    Let me know...here again...
    micro
I'm trying to hook up a 19" Sansui tv. I'm not on cable, but tried hooking it up to an antenna without any luck. What do I need to do to get the TV to work???
Make sure the TV can receive digital over the air signals (it should have an ATSC tuner), that is it doesn't need a digital converter box. In the menu settings make sure the TV is set to antenna, not cable. You should be able to use the auto-scan (auto-program, etc.) from the menu to find and program the local channels.
Feb 02, 2016 | Sansui Televison & Video
How do I program my RCA LED48G45RQ HDMI to digital channels
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Dec 09, 2014 | RCA Televison & Video
CANT GET CABLE CONNECTED RIGHT
Hook a VCR to it with a tape playing and make sure the VCR RF switch is set to channel 3. Then do the auto search. If it still does not find channel 3, then your TV has a bad tuning circuit.
Aug 08, 2009 | Zenith C27A24T 27" TV
Tv only gets lower channels
Go to settings manual, go to tuner mode, select CATV, than do an auto-programming or auto channel scan and you will be set.
Make sure it is not set to AIR
May 10, 2009 | Insignia NS-27 TV TV
Can't get it to go above channel 23... (nothing wrong with cable hook up)
all done so far looks good. But the part where you went into the menu is about i'd like to talk:
before you send to auto-program feature. try to find changing the band where the tv is working now.
Let me explain.
The tv is looking channels in the antenna or air band. Make sure you change the selector to CABLE.
this selection usually it is previous to send to auto-program.
if all this was done and nothing change, we need to send the tv into the workshop to check the tuner and voltages related to it.
Apr 14, 2009 | Televison & Video
Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Jan 23, 2009 | Televison & Video
Lost channels
make sure when tuning it you have it set to cable you will find that in menu. make sure you have it hooked up to cable. if you dont it will only program channels it sees. you will be able to see it program and tell if it is working.I hope this help
thanks Doctor video
Apr 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Blue Screen
I just wanted to suggest some things for you to try, if you have not done them already. Try hooking up a known good signal, such as the main input cable from your cable or dish, hook it straight to your tv, and see if you can change channels, and get a picture on low band...2 thru 6, and then if not, how about any picture above channel 6, if you get picture on 2 thru 13 now, it could be whatever you have hooked in between the input cable and the tv...be sure you have the tv on the right channel for your receiver, usually 3 or 4, or if you are using another type of video input cable, make sure you have tv on the right input for that cable and that cable is good...check the in and out of your component unit, for correct cable hookup as well as your cables, in reference to using RCA video and audio left and right in and out...a lot of sets and vcr's will go to a blue screen if they lose signal to them....I hope this helps you out some.If you cannot get a picture from hooking your signal straight to your tv, it could be the tuner got a spike from a thunderstorm, or has lost the B Plus source for the tuner circuit. Be sure that it is not selected for an input signal,other than the cable or antenna mode, the onscreen text should verify this, if you can change channels with or without getting video...a picture....Good luck with it. T.
Jan 15, 2008 | JVC AV-27S33 27" TV
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
Sanyo DVW-5000 DVD Player/VCR Logo
201 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
