Question about Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case
Wiring on power up 5511atx
I have two wires coming from the case wiring that are labeled CPU where do they attach, or what do they attach to?
    Genius:
  • 2,035 Answers
Please on this link:
Link:
Posted on Jun 19, 2008
    Genius:
  • 1,847 Answers
Need more information on the kind of wire
  • Legin Varghese
    Legin Varghese Jun 19, 2008
    where is it coming out off front , back and actually is it peeping out of the CPU box.
  • 13,433 Answers
They need to be attached on the motherboard front panel connector correctly what is your motherboard brand and model?
  • 3 more comments
  • Ekse Jun 19, 2008
    can you tell me more about the wires whats on the other end?
  • Ekse Jun 19, 2008
    is it connected to the temperature display?
  • Ekse Jun 19, 2008
    if its the temperature sensor you slip it between the cpu cooler, can you tell me more about the connector?
  • Ekse Jun 19, 2008
    is it like this one?
    thats a temperature sensor, it is put next to or between the cpu cooling or in this case taped to a harddrive
  • Ekse Jun 19, 2008
    please accept my solution or reply with a comment, I'm very confident that I can solve the problem with you.
All is standard, heater is gas, AC is electric, old thermostat was old and burned. I have TH3110D1008 and 4 wires.
the colors on standard t-stat are rh/rc gets red wire. g goes to fan green. y goes to outside unit cool. and in your case w labeled black goes to heat normally this wire is white.
Jul 25, 2015 | Heating & Cooling
My acer aspire zc 606 desktop will not turn on. I have tried unplugging power cord holding power button down for 45 secs. Is there anything else I can do?
First, you should remove the power cord from the PC before opening the side panel. Second, you should avoid static electricity by touching a bare metal part of the case before touching anything else in the computer. It's possible that the power on/off switch on the front panel of your PC is faulty. Inside the case on the motherboard you will find several wires coming from the front panel which connect to pins on the board. one wire is labeled PWR. Unplugging this wire reveals the pins which are very close together. Using a screwdriver to touch both pins at once will power the computer on. Of course, the power cord must be reattached in order for this trick to work so be extremely careful! If the PC is still under warranty then attempting to replace the on/off switch yourself may void the warranty.
The other possibility is that the power supply, or the cpu, or the motherboard itself is faulty. In this case, take it to a computer repair shop.
Jan 31, 2015 | Acer Computers & Internet
I dont no where to plug in the wirers on my tower
Your Dell desktop computer will come with all of the equipment you need to hook it up and get it started right in the box with the main CPU. You will have all of the peripheral equipment and cables that you need to connect your desktop to your keyboard, mouse, monitor and, most importantly, a wall outlet or surge protector to provide it with power. The entire hook-up process shouldn't take more than a few minutes. Connect your computer monitor to your Dell computer using the included blue VGA cable. This VGA cable plugs into the blue video input on the back of your Dell computer and into the identical input on the back of your monitor. Plug your monitor's attached power cable into a wall outlet or surge protector. Plug in your keyboard and mouse. Dell computers ship with USB keyboards and mice, so take the USB cables that are permanently connected to each device and plug each of them into one of the available USB ports on the back of your Dell computer. You can use the ports on the front of your computer if you like, but as your keyboard and mouse don't get unplugged with any kind of frequency you may want to conserve those inputs for removable devices like flash drives. Connect your Dell computer to a wall outlet or surge protector using the included power cable. The power cable plugs into the power outlet on the back of your Dell computer and into a regular power outlet on a compatible device. Press "Power" on your Dell computer as well as on your monitor. Your computer will turn on and begin to boot into Windows.
Hope this helps. For reference, you may want to read this section describing the cables and connectors coming from the power supply, and/or this section describing the connections on the motherboard. Motherboards and system cases vary. Your motherboard may not have all the items I mention here, and the same holds true for your case. Furthermore, you may find that your case and motherboard don't match in every situation; for example, some cases have a turbo button and some do not, and some motherboards have a connection for a turbo button and some don't. Watch out for "off by one" errors when attaching cables to pin headers. In particular, some motherboards combine several pin connectors into a larger block. The individual connections are the same, the motherboard just physically groups the pins together into a larger matrix. Be careful when working with these as making a mistake is much easier to do. Refer to the manual. If the system is in a tower case, it is much easier to perform this procedure with the case resting on its side. LEDs have two wires and are unidirectional, so they will not work if attached backwards. You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative. Unfortunately, the case connector almost never has the positive and negative labeled. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work. One tip you can use: most cases employ for each LED one colored wire (green, yellow, red, orange, blue) and another wire that is either black or white. When this is the case, usually the colored wire is positive (signal) and the black or white wire is negative (ground). This isn't always true, but it's better than a random guess in most cases.
Jan 20, 2013 | Dell Computers & Internet
Can't remember where the wires go on the motherboard Dell ry206 can anyone help please?
what wires are you referencing?
this is a SATA MOBO with 24 pin power and 4 pin CPU. the wires to front of case are labeled on wire end and MOBO Blue sata is usually primary to Hard drive but should be labled 1,2,3,4. wires in back are USB Keyboar & mouse, lan and speaker
Why are the wires off?
Jul 13, 2010 | Dell Computers & Internet
How do I plug the Power Button wire into the motherboard?
Printed on the MB
HD LED +1 -3
PWR LED +2 -4
RESET 5- 7+ (Why the changed order? & there's no reset button on this computer.)
PWR ON +6 -8
There are nine pins with a little triangle pointing at one and a 2 next to another.
The pins on the MB look like this:
2ndpin
1st pin
Found some info on the 506GR. Unfortunately Gateway is keeping the service manual a big secret.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | Computers & Internet
My father in law opened the case to clean out the dust and now the computer won't turn on at all. there are three small wires that are loose they are labeled power sw hdd led and another led i can't...
they should be attached to the pins on the motherboard as they are normally marked on where they go
the pins are on the edge nearest the bottom front of the pc
they normally look like this
just a case of matching them up to the wiring
if your not sure then go to motherboard manufactures website and download the manual from there.
Aug 18, 2009 | eMachines W3506 PC Desktop
Hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
May 16, 2009 | HP Computers & Internet
No power on .. wire detach from power button in the front panel ... where do the wire go so i could re attach them .. thanx ?
the connectors are labeled.power switch is labeled PS.reset, RS.you can reattach them by following the labels.
May 11, 2009 | Dell Dimension 2400 PC Desktop
Case wiring
For the wires that comes in your CPU casing, mostly used for your front panels like power switch, hdd status, power led, etc. It is indicated on the pins itself so you might not be confused. there are some that comes for front panel USB. (with codes like vcc+ /- ,etc.). The best you can do is to read your Mainboard manual on where you place this pins.
Feb 25, 2009 | Avus A450-3001 Micro ATX Mid-Tower Case
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case Logo
193 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
