Question about HP Photosmart C3150 Printer
HP C3150 error flashing....not printing!
My HP C3150 All-in-One:  check print cartridge red button is flasing (color cartridge is new) and color button under start copy section is also flashing.  Help!!  Thx!
  • 2 more comments
  • vjcorey Jul 31, 2008
    New color ink cartridge, printer says no color cartridge. Color indicator flashing. Error light flashing.
  • Anonymous Oct 17, 2008
    after replacing both cartridges (color and black), I printed 1 sheet with no problem. Then the black ink cartridge missing light flashes and printer will not print. cartridges were new.
  • clark12 Oct 23, 2008
    I have the same problem. It is 2 years old and has been minimally used.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the carriage moving freely when you open the door?
    Was there any paper from a jam stuck in there?
You may have got a bad ink cartridge, I would try changing it again to see if that helps!!
Posted on Aug 24, 2008
Hp photosmart c3150 keeps color light and check cartridge light keeps bliking after replacing with a new one.
It sounds like you ink cartridge is electrically bad; you can run the diagnostic 'tap 41' test to confirm. The HP 31xx printer 'access procedure' will be very similar to this HP Fxxx series access procedure:
http://www.youtube.com/watch?v=m-OM09NvNqg
Good luck:
inkjet411.com
Feb 19, 2013 | HP Photosmart C3150 Printer
HP C3150 is printing green instead of yellow. How do i get yellow?
You should first check your ink levels to make sure you have enough of all colors. Do this through the printer toolbox on your pc. If the ink levels are fine you should print out a diagnostic page. Follow these steps to print out a test page: 1. Press and hold the cancel button 2.Press the start copy color button. 3. Release both buttons.
If there were problems with the test page run the clean print cartridges utility. This can be found in the printer toolbox in the device services tab.
If that fails as well, you should look at replacing your ink cartridges with new ones.
Apr 22, 2011 | HP Photosmart C3150 Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Turning off the color cartridge
I have been fighting the same annoying issue for several hours this evening. I even used HP Live Chat and was told I needed to buy new cartridges. I'm not satisfied with that answer of course. Out of nothing more than a whim I told my puter to print a txt document I had open at the time...IT DID...with the red error light flashing and a color cartridge error on my display panel.
This was just a few minutes ago so I have no further info to offer. I look forward to seeing what others have to day regarding this issue.
Jan 14, 2008 | HP PSC 750 All-In-One InkJet Printer
HP Photosmart C3150 Printer Logo
934 people viewed this question
Ben Johnson
