Question about Microsoft Visual Basic 6.0 for PC
Unhandled exception in VB6.EXE: 0xC00000005: Access Violation. Error throws while opening vb application
Fardinfard
  • 392 Answers
SOURCE: installing vb6
Dear friend, I suggest you this website, you'll get all your answers there:
http://www.codeproject.com/
Good Luck
Posted on Feb 09, 2009
fblock
  • 289 Answers
SOURCE: how to access data from ms access with buffer in
Use ADO and create a connection string for a Jet file (version matters here when creating the string). Then use ADO commands and return recordsets to buffer your data.
Posted on Apr 24, 2009
gewiz
  • 1271 Answers
SOURCE: I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Regards
GeWiz.
Posted on Jun 16, 2009
  • 29 Answers
SOURCE: Access violation at address 0052D602
Sorry If this doesnt help your problem but here is some info that might help
Consent.exe is part of Windows Vista - it's the User Access Control (UAC) executable.
There is a known malware version of this executable. Do a search on your hard drive (within Windows Vista, obviously) for all consent.exe files - make sure you include hidden and system files in the search criteria.
Once the search has completed, right-click on each file and check the file properties.
There is a MalWare version of Consent.exe
Right Click ALL of the ones you find and look for
Microsoft details in Properties
  • File Names Used: 3
  • Paths Used: 8
  • Common File Name: CONSENT.EXE
  • Common Path: ?:\windows.old\windows\winsxs\x86_microsoft-windows-lua_31bf3856ad364e35_6.0.5728.16387_none_ef1113b929fe5371\
  • Vendor Information: Microsoft Corporation
  • Product Information: Consent UI for administrative applications
  • Version Information: 6.0.5728.16387
  • CONSENT.EXE may use 3 or more path and file names, these are the most common:
  • 1 :%windir%\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 2 :?:\windows.old\windows\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 3 :?:\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • If you find a consent.exe anywhere else in the search results, I'd delete that file. Run a thorough anti-virus scan of the harddrive. I'd also download spybot and run it as well as downloading Ad-Aware from Lavasoft and using it to scan as well.
    Spybot and Ad-Aware can find different spyware/malware, which is why I recommend running both products.
    Once you've done all that, reboot the system. That should fix the problem.
    Posted on Jun 22, 2009
    wiqi546
    • 1511 Answers
    SOURCE: Problems with VB6 Make .EXE command:
    I guess your compiling logs are absent, or have been corrupted, which are only used to when you publish/make an executable.
    To Confirm this, Make your EXE through Command Line Compiler, and How See this
    If its still not working and your Project is important, then make a blank project and copy paste all Source and Objects there.
    Regards,
    Waqar.
    Posted on Aug 21, 2009
    Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
    http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
    Fatal Error while opening AutoCAD Dec 05 2014
    Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
    See More
    Issue:
    While in the process of starting AutoCAD , a Fatal Error occurs.
    Causes:
    Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
    Solution:
    There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
    Sep 16, 2010 | Autodesk AutoCAD 2010
    When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
    See More
    Issue:
    Causes:
    Solution:
    If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
    Article ID: kA230000000tTXu
    Sep 15, 2010 | Autodesk AutoCAD 2010
    Unhancled exception access violation (c0000005) at
    i fixed on my pc:
    C:\Program Files\Diablo II\D2VidTst.exe – ran this and switched to direct draw 2d
    Mar 20, 2010 | Blizzard Entertainment Diablo 2 for...
    Delete blank rows in excel using visual basic
    have you tried to read in one file and write back in excel format only the non-blank rows?
    Mar 11, 2009 | Sony Playstation 3 (PS3) Console
    Microsoft Visual Basic 6.0 for PC Logo
    343 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
