Question about Radiant Morning Tech Naomi
Morning, I have a problem with Naomi Filter 3.2.90 installation on OS Windows XP SP3 and Internet Explorer 8. When filter is working I am not able to open Explorer. I have to disintall the filter to work with browser. My opinion on Naomi is very good and I would like to work with the filter on PC. Can you help me as soon possible? Thanks
Is windows internet explorer 8 the same as microsoft internet explorer 8
Restoring Computer to earlier state is the best solution. Only update the Internet explorer by using online updates that is downloaded from Microsoft website. WebRepOverall ratingThis site has no rating(not enough votes)
Also try to update the drivers that control your PC.
If problem still occurs then use system utility tool PCFresher that will fix windows internal errors and will fix corrupt registry errors.
Dec 07, 2012 | Microsoft Windows XP Professional for PC
Tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 | Computers & Internet
Tip
INTERNET EXPLORER 8 CANNOT INSTALL IN WIN XP SP2
IF INTERNET EXPLORER 8 CANNOT INSTALL IN YOUR WINDOWS XP SP2. THEN U CAN INSTALL IT AFTER INSTALLING "WindowsXP-KB936929-SP3-x86-ENU.exe" (search from google download from microsoft site. the file is of 316MB.) AFTER INSTALLING THIS YOU CAN INSTALL INTERNET EXPLORER 8. IT WILL ALSO UPDATE YOUR WINDOWS FROM SP2 TO SP3
on Dec 22, 2009 | Microsoft Internet Explorer 8
I want to know on how to uninstall IE8 on my computer i am running a windows XP service pack 3. I just want to install a fresh copy of IE8 . . . . .
Hi josephc_agni,
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    NOTE: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative step given below.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
ALTERNATIVE STEP:
  1. Carefully select and then copy the following command: %windir%\ie8\spuninst\spuninst.exe
  2. Click Start, and then click Run.
  3. In the Open box, type Cmd.exe, and then press ENTER.
  4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
Dec 05, 2010 | Microsoft Internet Explorer 8
I have downgraded the OS of my Toshiba Satellite A205-S7468 from Windows Vista to Windows XP SP3. System is having trouble identifying the proper Audio Driver. On Windows Vista, the Audio Driver is...
You can try with an automatic driver tool, yes of course, it could be installed manually, but to avoid the hassles, you better opt for a driver utility.
Download and install this software (Device Doctor Free). Once it's installed, run the program and click "Begin Scan", wait for few seconds until the scan completes and search the scan result for realtek, if so click it, the direct download page will open up, download and install the driver, that should work without any more hassles.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Oct 27, 2010 | Toshiba Satellite L45-S4687 Notebook
I get an error message when trying to install internet explorer 8. the SHregGetValue entry point cannot be located
first clean ur windows, check for errors, run chkdisk, repair windows registry with reginout and then install ie 8
Sep 28, 2010 | Microsoft Windows XP Professional SP3 Full...
Unable to load internet explorer 8 on my window xp Prof sp2
Install SP3 and any other updates first.
IE 8.0 was also offered as part of sp3.
It may well depend on some of the updates to be installed.
Mar 18, 2010 | Microsoft Internet Explorer 8
My Reason 4.0 recently began freezing on start up. I am using Windows XP SP3 on a Dell Inspiron 531s. Reason has worked fine for about a year, and now suddenly I can't get it started. Any thoughts?
There is probably more things that it could be then there are that it couldn't. First I would try to uninstall and reinstall the software and go from there.
Thanks,
Lee
Aug 07, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Ie8 failed to install with xp sp3
Try reinstalling SP3. But, you may need to disable your anti-virus software, first.
Jun 14, 2009 | Microsoft Internet Explorer 8
Computers & Internet Logo
77 people viewed this question
Top Radiant Morning Tech Computers & Internet Experts
David Payne
David Payne
Are you a Radiant Morning Tech Computer and Internet Expert? Answer questions, earn points and help others
