Question about Sanyo PLC-XU41 LCD Projector
Plcxu41 standby mode how is this setup? - Sanyo PLC-XU41 LCD Projector
    Brigadier General:
  • 8,909 Answers
This unit will go into standby if no signal is present for a few minutes. Pressing any button will return it to normal operating conditions.
Hope this helps.
Posted on Nov 15, 2010
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
ONKYO TX-SR307. Problem with volume/sound getting lower. "Setup" does not alter / resolve the issue. Please help
Hi, if this has not been resolved please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Mar 02, 2015 | Onkyo Audio Players & Recorders
Sansui tv chassissv21918n
HAVE YOU GONE TO SETUP TO SEE IF YOU CAN DESELECT/UNSELECT STANDBY MODE?
Jun 13, 2014 | Televison & Video
Can't return from standby mode. the vga, sound,
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
May 31, 2011 | Computers & Internet
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
My niece decided to push a rather odd sequence of buttons on the sound system and now nothing is setup correctly. while i have fixed the niece problem, i have yet to figure out why i cant fix the sound...
It's in the manual on page 59.
1 Press STANDBY/ON on the front panel to set this unit to the standby mode.
2 Press and hold
The advanced setup menu appears in the front panel display.
3 Press PROGRAM l / h to select “PRESET”.
4 Press
STRAIGHT repeatedly to select “RESET”.
Select “CANCEL” to cancel the initialization procedure without making any changes.
5 Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
• This procedure completely resets all the parameters of this unit including the set menu parameters.
• The initial factory settings are activated next time you turn on this unit.
To cancel the initialization procedure at any time without making any changes, press STRAIGHT repeatedly to select “CANCEL” and then press STANDBY/ON.
Aug 14, 2010 | Yamaha HTR-6130 Receiver
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
Standby mode is not working..
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, would suggest going into the CMOS/BIOS setup and restoring all configurations/settings back to default. Should this be not corrective, try verifying settings inside the Properties box of the Power Options inside Control Panel.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | Acer Aspire 5000 Notebook
Sanyo PLC-XU41 LCD Projector Logo
70 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
