Question about Acer Aspire One PC Notebook
What is the circumference of a rectangle? - Acer Aspire One PC Notebook
    Brigadier General:
  • 8,909 Answers
A rectangle has not got a circumference it is not a circle!
Posted on Nov 15, 2010
406 squaret feet of insulation = how many linear feet
wall or pipe? -If walls -wall studs set at 16" wide apart x 8' tall would be 10.64 sf(example) each so times width of wall x height of wall.
--if a Pipe then--
4" PIPE 12.57 Circumference(in) 12.57 sq.in
5" PIPE 15.71 Circumference(in) 19.64 sq.in
6" PIPE 18.85 Circumference(in) 28.27 sq.in
8" PIPE 25.13 Circumference(in) 50.27 sq.in
Mar 05, 2015 | Insulation
How to adjust achoke on 1979 mg 94 cubic engine has antifreeze running through it
You need to calibrate the heat mass before reassembling the choke unit. This is from John Twist of University Motor. Hope it helps.
Loosen the 1/2" headed bolt that fastens the water jacket to the heat mass. Then, disconnect the two hoses from the water jacket and plug them with 7/16" bolts. Remove the bolt the rest of the way and CAREFULLY lever the water jacket away from the heat mass. Then, remove the three screws that hold the heat mass to the auto choke.
Remove the heat mass and carefully remove the black plastic insulator. Now you can work with the auto choke and calibrate the heat mass.
Copiously oil the inside of the autochoke, and exercise it -- hold the throttle wide open and move the little lever which engages the bi-metal strip of the heat mass from its 3:00 position to the 12:00 position -- about twenty times.
Place the heat mass in a pan of water and bring it to a boil. Pick the heat mass from the boiling water and inspect the alignment of the bi-metal strip -- well, really the rectangle -- and the line scribed in the circumference of the heat mass. That line is usually ill-defined or worse, completely obliterated. Cut a new line with your hacksaw wherever the rectangle is positioned.
Now reassemble the unit, taking GREAT care to match the finger of the choke with the rectangle of the bi-metal strip. Position all three lines (the boss on the auto choke body, the raised line on the black plastic insulator, and the line you just made with the hacksaw), in line.
Feb 25, 2015 | 1956 MG Midget TF
15" circle what is outside measurement
If you would like to know the circumference of a 15" diameter circle this is the formula:
circumference = radius x 2 x pi
circumference = diameter x pi
in our case:
circumference = 15" x 3,14
circumference = 47 ,1" (that's 119,634 cm)
May 06, 2014 | Cars & Trucks
Help finding the circumferance of a circle
The circumference of a circle is given by the expression
Circumference= 2* PI* Radius of circle
C=2*Pi*R
The area is given by
Area of a disk with radius R = Pi* R*R or PI*R^2
Area= PI*R^2
Mar 11, 2014 | SoftMath Algebrator - Algebra Homework...
Need to find circumference when you know the diameter is 2
d/2=r, circumference = 2 x pi x r , pi = 3.14159, so circumference = 2 x 3.14159 x (d/2)
Jan 08, 2014 | Computers & Internet
Create a flowchart that computes for the circumference of circle. Assume that the value for radius is 7.23.Your flowchart should be able to show the value of the circumference.The pie value is 3.1416 which...
Create a flowchart that computes for the circumference of circle. Assume that the value for radius is 7.23.Your flowchart should be able to show the value of the circumference.The pie value is 3.1416 which is constant and never be changed.You can compute the circumference by using this formula 2piR?
Jul 06, 2011 | Computers & Internet
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
Diameter of a circle is 2.3cmcalculate the circunference of the circle.use 3.14 for pi
The problem is not related with PC or Laptops. But it is true the question may be related with computer language.
Ans in QBASIC:
10 REM DETERMINE CIRCUMFERENCE OF A CIRCLE 20 PRINT "DIA = D = 2.3cm CIRCUMFERENCE=C PI=3.14" 30 D=2.3 40 C=3.14*D 50 PRINT "CIRCUMFERENCE, C=";C 60 END
Ans in C:
#include<stdio.h> define pi 3.14 main() { float d=2.3,c; printf("\nDiameter D=2.3cm given"); c=pi*d; printf("So the circumference is(in cm) =%.3f",c); getch(); }
Jun 08, 2010 | Computers & Internet
What is the radius of a 30'' pipe
30" diameter? Radius is 15" (half of diameter).
30" circumference (distance around) is a little more complicated...
The number pi.gif is the ratio of the circumference of a circle to the diameter. The value of pi.gif is approximately 3.14159265358979323846...The diameter of a circle is twice the radius. Given the diameter or radius of a circle, we can find the circumference. We can also find the diameter (and radius) of a circle given the circumference. The formulas for diameter and circumference of a circle are listed below. We round pi.gif to 3.14 in order to simplify our calculations. diam_formula.gif circum_formula.gif
Nov 17, 2009 | Gateway FPD1975W 19" LCD Monitor
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
