Question about JohnnyVac JV115 Wet/Dry Vacuum
Johnny vac wet vacuum
The float that is supposed to shut the vacuum down when tank is full is not functioning properly. it shuts the vaccum down even when its empty.
dave
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
Filters have been clogged with wet cat litter and now the vac will turn on but shuts off and wont cont to vaccume. can we clean/rinse the filter out. filter light has come on and then turns off once the...
Using a vacuum cleaner for wet cat litter??? Not a good idea at the best of times! The machine's cutting out because it's overheating. You don't tell us the make or model of your machine - some filters are washable, many are not. Your user manual should tell you. As a general rule, cloth- or sponge-type filters are probably washable, paper ones are not. If you do wash the filter, give it at least 24 hours in a warm place to dry thoroughly before re-using.
Jan 24, 2010 | Vacuums
The red ball pops up periodically; why is that?
The red ball is the float/shutoff for full tank. That prevents water from overflowing and being sucked in to the vacuum motor. When the float shuts off the vacuum to the tank, the tank needs removed and emptied of dirty water. The float may get activated prematurely if the foam sock around it is dirty. It may be removed and rinsed.
Oct 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Auto-matic suction shut-off didn't resume once tank was emptied
look on the bottom of the tank and there should be a fitting on there take it off and clean..there should be some hind of float inside the tank.turn it right side up and tap on the tank the float might be stuck
Apr 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Recovery tank not filling
The tank has an automatic shutoff float (red) that will stop the suction if the water level gets too high. this can also happen if the tank is not level or clean as the float can bounce around and jam at the top. I've actually had this one happen). I would make sure the float is down during the cleaning and see if the suction comes back. if not, please provide more details and we'll get 'er fixed!
Feb 04, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Auto matic shut off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40664&thid=657597
Automatic shut off
Posted by clean mama on Jun 09, 2008
When the recovery tank is full the yellow float disc is supposed to raise to the top of the tank lid... it does not. Other than that, the machine is working fine...
Ever since I hooked up the hose and attachment to clean some upholstery, now that I am back to cleaning carpet... I have this issue with the yellow disc
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5912-900 Upright Steam Vacuum. The yellow disc is supposed to act like a float when the water raises the yellow disks will let you know the water recovery tank is full, and not actually turn off the system. You may want to check with your local vacuum dealer to see if the yellow disk is broken or find out why it is not working correctly. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Hoover F5912-900 Upright Steam Vacuum
JohnnyVac JV115 Wet/Dry Vacuum Logo
48 people viewed this question
Top JohnnyVac Vacuums Experts
Are you a JohnnyVac Vacuum Expert? Answer questions, earn points and help others
