Question about Radio Shack Pro-2052 Scanner
I can not program any new stations. after i press the enter button it clears my channel that I entered.
    Problem Solver:
  • 8 Answers
,gfnc,mb,dxvjbdjkbg
Posted on Nov 15, 2010
Need manual for bush cdab51rr
On my Bush cdab51rr radio, the select button is marked ENTER. Hence:-
Choose the required station with Left/Right arrow buttons, press ENTER. Press and hold PRESET button until number flashes.Quicklyicon1.png scroll through preset channels with arrow buttons.When required preset chosen, press ENTER.
Jan 13, 2012 | Audio Players & Recorders
Tip
How to setup/turn on/off the V-Chip
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
on Jan 21, 2010 | Televison & Video
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
Raidoshack 1000 channel scanner
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Mar 07, 2008 | Radio Shack Pro-97 Handheld Scanner
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Radio Shack Pro-2052 Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
