Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After start work 3 seconds and the red light comes on and power off
  • k_sotirov Nov 15, 2010
    Sanyo Projector PLC XU83 will not power up
    lamp is replaced
    Thanks for your help!
    Projector was worn in the service but not fixed it
    I have a service cable,
    please send service program and Projector service manual to repair
    cooling fans is OK , clean filters ,
    Brigadier General:
  • 8,909 Answers
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Posted on Nov 15, 2010
    lamp is replaced
    cooling fans is OK , clean filters (ok)
    k.sotirov@ecopharm.bg
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
I have an Sanyo PLC-SU07E Multimedia projector. I
4,select "Yes"
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 09, 2013 | Sanyo PLC SW20A Multimedia Projector
I had my sanyo plc xu70 suspended from ceiling.. how do i rotate the image?
2,Press the Left ,Right,Up or Down to find the "Option" .
3,select "ceiling"
4,select "Yes"
Have a good day!
Mar 26, 2012 | Sanyo Projector Lamp for PLC-XU70
I need reset counter lamp projector sanyo model: plc-xu300
4,select "Yes"
have a nice day!
Feb 15, 2011 | Sanyo PLCXU300 Projector Lamp
How to find out lamphour in PLC-XT11
hi
do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
the pointer to [Yes] and then press SELECT button.
3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
ok
Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
I need to replace the projector bulb
hi,
for replacing the lamp do the fallowing.
1 turn off the projector and disconnect the AC power . allow the projector to cool for at-least 45 minutes.
2. remove the screw at the bottom to oppen the lamp cover.
3. after that remove 2 screws of the lamp and pull out lamp by grasping the handle.
4. replace the lamp with a new one and tighten the 2 screw s back in to position make sure that the lamp is set properly. replace the lamp cover and tighten the screw.
5. connect ac power turn on te projector and go to the menu select lamp counter make it zero
Replacement lamp type number is : POA-LMP90
OK
Dec 15, 2010 | Sanyo PLC-XU73 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Open Questions:
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
