Question about Nokia E63 Cell Phone
Keypad will not respond. Perhaps memory too full but cannot delete messages. I have no memory card. Have tried to save data to Nokia pc suite without success. What can I do?
  • rand398752 Nov 15, 2010
    What is stripe?
  • 527 Answers
It may due to stripe check it
Posted on Nov 15, 2010
  • 1 more comment
  • pronkyfruit Nov 16, 2010
    a plate or like a circuit board placed inside the phone
  • rand398752 Nov 16, 2010
    Thnak you. I fixed it by deleting apps
  • pronkyfruit Nov 17, 2010
    nice
I have nokia 5300 ..and it has very less phone memory left..due to that.it is not switching on..When I switch it on,It says to enter the security code.and when I enter the correct code ,it gets hang...
i'm also using nokia 5300 xp msc. It will hang when you start or on the handphone. Sometimes it also will restart automatically.
it your screen became white?
nokia 5300 ,it need you to reduce mesagge(inbox, outbox )size that you use. I'm always save my mesagge to pc using pc suite . This because handphone memory is not to big. it around 5mb-3mb. When you have many message in inbox ,outbox or save folder, it will make your phone memory became low. other things all picture, video,song I save it in memory card.
if your handphone have white scrreen. Then you can save it. On phone without memory card. and wait until your phone is ready to use.before this, I also face this problem, and sometimes it does not have response and hang always. After I get that phone ready to use, I'm delete message and save to pc using pc suite. It need more time. But it more easy rather that you using phone to delete one by one that message that you dont want. Try it. good luck
Jul 01, 2011 | Cell Phones
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
My new nokia n900 phone tells me memory full, delete data to free memory but i have 26 G memory available. because of this it can nnot save messages and other files. what can possibly be the problem please
Back up all your data and file(s), example your contact and messages. Install Nokia PC Suite latest version from the website nokia. By installing nokia pc suite you can open your phone memory card and memory card to save it to your computer. After saving your contacts, messages and other files it is time to format your nokia n900 using nokia pc suite. Then test you phone.
Nov 13, 2010 | Nokia N900 Smartphone
Mmeory Full. Delete some Data
when saying memory full that does no mean the text messages memory is full it means the phone's memory is full, the messages are saved on you sim card so try deleting some app on you phone
May 14, 2010 | Nokia N95 Cellular Phone
Memory full. Please delete some data.
press *#7370# to reset phone but make a backup
Jun 30, 2009 | Nokia N73 Cellular Phone
Memory full, delete some data
  • Click on Messaging.
  • Click on options follwed by settings,
  • Click on Other
  • Select Memory in Use Change it to memory card.
If you Memory card is also full. Backup all your data  to your PC and delete some data in your mobile.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | Nokia N70 Cellular Phone
Phone memory is full , cant delete any data from contact and message .nokia 3320
Did you try to call your service provider for technical support?
Jan 04, 2009 | Cell Phones
Step1 Perform a soft format of your phone by dialing *#7370# just as you would any other phone number. This will erase the contents of the phone's internal drive. Step2 Use a hard format only if absolutely necessary; this sequence will reset your phone back to its original factory settings. Step3 Turn your phone off. Step4 Hold down the green answer, * and 3 buttons. Step5 Switch the phone on without releasing the buttons. Step6 Release the buttons when "aFormattinga" appears on the screen.
Dec 05, 2008 | Nokia N73 Cellular Phone
Showing memory full
the bestb thing to do is formatt your unit, and the MMC'
after you have formatted the MMC in you phone,
set you massage in setting>other>select MEMORY in USE' put in MMC in use. so all uyour massage will directly save in MMC even it has High mb/kbs...
Mar 11, 2008 | Nokia N70 Cellular Phone
Nokia E63 Cell Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
