57.03 Error in LaserJet P3005. i need a solution
  • 65 Answers
SOURCE: hp laserjet p3005 error message 49.4c02 error
Turn the printer off. Remove any jobs i the printercue. restart, and the printer should be OK.
Posted on Aug 03, 2009
  • 11800 Answers
SOURCE: memory test failure replace dimm 0
Exactly what the message says: the RAM memory of the printer (first module - DIMM0 - to be more precise) has failed and must be replaced - it happens. It's better to take it to a repair shop, i doubt you have the necessary skills to dismantle the printer and replace the module yourself
Posted on Dec 03, 2009
Testimonial: "Thank you, Azraelsrl, especially for the very prompt answer!"
  • 81 Answers
SOURCE: close top cover error on laserjet p3005
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer
Posted on Jan 01, 2010
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
  • 87 Answers
SOURCE: 49.4C02 Error
The P3005 is known to have problems with a chip on the formatter, gives various errors to include the 49.2d9d, blank display and others. HP has not issued a recall or service advisory but is fully aware of failure of the chip on the formatter. Repair for this is to print a configuration page, replace the formatter board, bring the machine back up in service mode and put in the correct serial, service code and page counts into the new formatter's nvram memory.
Liberty Parts Team at lbrty.com has refurbished formatters at reasonable pricing with no return core to worry about. The PIN needed to access the service mode is 10300506.
Other problems with the P3005 are grinding in the fuser area, correctable by removal of the fuser, replacement of the 4 accessable gears in the side (left as you look into the back) and the main gear on the fuser then put the fuser back in and should be good.
Service manual available for free at feedroller.com - down the left navigation bar near the bottom is an icon and link to service manuals in PDF. No need to make someone on ebay rich selling copyrighted pdfs.
Posted on Jun 25, 2010
57.0 error on Hp LaserJet P3005
According to the service manual this is a sub cooling fan error. This fan is on the left side of the printer. 25365811-vovdf0wduqj1a05k1fbz2dih-2-1.jpg
Jan 12, 2015 | HP LaserJet P3005n Printer
Error 57 03
Buen dia un favor, tengo un aimpresora hp laser 2410 y me sale error 57,03 me podrian haer el favor y me colaboran?
GRACIAS.
Jul 23, 2013 | HP LaserJet P3005n Printer
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 03, 2011 | HP LaserJet P3005n Printer
49.4c18 error
This is a formatter error!
Process to resolve:
Unplug the power cord from the machine, and leave it disconnected for about 10 minutes. Plug it back in and power on.
If the error still persists you will need to replace the formatter. Formatter errors occur mostly when sending over .PDF files if it's a communication based issue. However the P3005 are notorious for having the formatters go bad.
Jan 09, 2011 | HP LaserJet P3005 Printer
Error 52.0
Hewlett Packard P3005 52.00 Error - Indicates a critical Laser Scanner error has occurred.
Loose cable connections or faulty laser scanner.
*** The Laser Scanner should only be accessed by qualified individuals. ***
Resolution - Power cycle the printer - if the error persists, change the scanner.
Part Number Laser/scanner assembly RM1-1521-030
www.partsnow.com
Dec 28, 2010 | HP LaserJet P3005 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
HP p3005 printer cartridge error but cartridge is ok...how to solw this error..
The cartridge is not ok. Just because you replaced it doesnt mean its a god cartridge. You installed a bad cartridge so replace it and get your money back for the old one. P3005 printers are very intelligent!
Jul 15, 2009 | HP LaserJet P3005 Printer
Error message 52.00
HP LaserJet P3005 Printer- just changed toner and now service error displayed, tried to power on/off still not working??
May 14, 2009 | HP LaserJet P3005 Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
110 people viewed this question
jasbo
jasbo
