We moved house and when we set the tv up, the set top box kept saying "no signal"
    Brigadier General:
  • 8,909 Answers
Check you have an aerial connected to the lead you are using.
If the aerial is on the roof, has it got an inline box about 18" from the aerial? If it has it is a mast head amplifier and requires a power supply to work.
Hope that helps.
Posted on Nov 15, 2010
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
My tv says "digital channel signal strength is
On the tv remote look for Mode Select, move switch to TV then "03" then press enter. Then pick up cable remote make sure the "cable button lights up ( by pressing on cable button at top) then you press guide...Voila!
Sep 14, 2011 | Sansui HDLCD-4212 LCD TV
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do I get the closed caption to turn off? It's been on for weeks, all the time. I've tried to turn it off from the remote: I press "menu", scroll down to "features" , go to...
What is the Source of the video? The captions menu item that you found will only enable/disable the closed captions from select sources, including your TV antenna or RF cable. For other sources (particularly HDMI), you need to disable the captions using the options for that source.
On my IPTV (fiber-optic TV) box, that requires entering the setup menu with a passcode from my provider. Next I go to the Hardware menu and find the captions option under the Audio sub-menu. On one satellite setup, I found that a secondary set-top box could only get the closed captions if they were enabled on the primary set-top box. Thus disabling the captions required accessing the set-top box's menu from the correct TV.
I hope this helps. Please add a comment with your TV source (make and model), if you'd like help finding the CC option menu for that device.
(With a slightly different IPTV set-top box, the included remote had a CC button that worked without needing the passcode. The current one doesn't.)
Jan 21, 2018 | Philips 42PFL3704D LCD TV
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
I just moved, trying to reconnect set top box Teac HDB843, but it says 'no signal' on tv screen
I would suspect that if you have just moved you may not have an aerial connected. If you can't see one outside or in the loft then that is the problem.
pete
Dec 15, 2010 | Televison & Video
I have a motorola dch70 cable box from comcast. I recently hooked it up and set it on top of my TV. I cannot get any info on channels or any info when I hit guide. If I hit the ondemand button it says...
you say that it works if you move it away from the tv set, its due to the electrical interference of the high frequency internal tv signals with that of cable box, you need to shield/reduce the interference by either moving the box away from tv set or placing the box on a grounded metallic plate on the tv set
Jul 29, 2010 | Televison & Video
My analogue tv doesn't do anything when connected to the new set top box. The scart is connected and the aerial also. Are there some anologue tv's that can't receive the digital signal? I already have 1...
Have you checked that your aerial is connected into the set top box & not into the TV? The aerial signal has to go into the set top box & then the box will be connected via your Scart cable into the TV. On the TV you will need to select the Scart input ie. AV1. This should give you the set top box incoming signal, you might then have to tune in the box by following the on screen instructions. Hope this help.
Nov 02, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
