Question about Dell Vostro 1510 Laptop
Hi .. i have dell 1510 with windows vista , when i watch video on web or sometimes on the stored ones or even run some java applications on web, the PC becomes so slow and flickered till it freezes, i tried to update all programs but nothing is working
  • 2,567 Answers
First, make sure that both the video adapter's drivers & the motherboard's chipset drivers are installed properly & that they are up to date. You will need to check Dell's web site for any updated drivers, then download & install them. Here is the page you would want to check for updated drivers: Drivers & Downloads for Vostro Notebook 1510
If this did not help resolve your problem, make sure that your laptop is not overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked. You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Further more, you might need to check the thermal grease on top of the processor's & the graphics adapter's surface. If you found that it has dried up, you will need to carefully remove it off the surface of both chips using a clean soft cloth, & then re-apply fresh thermal grease. You can buy it at electronic stores or Radio Shack. Beware that this will require that you disassemble the laptop to the level where you could got access to the heatsink/fan assembly.
Full illustrated instructions on disassembling the Vostro 1510 could be found in the
Dell Vostro 1510 Service Manual
Hope you find this helpful
Posted on Nov 15, 2010
Webcam not recording video
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer The Dell Inspiron line of laptop computers allows consumers to customize their system in a number of ways, from hardware specifications to color. The laptop also comes with an integrated webcam that can be used as a camera and for video Web chats. You can use the camera from the Dell Webcam Manager application, which controls all the functions of the camera.
Click the "Start" button on your computer, highlight "All Programs," and select "Dell Webcam Manager" from the list of available applications. Click on the "Webcam Center" icon. From the tab at the top of screen, select the action you want the camera to perform. You can use the camera to record videos, snap photos, detect motion, monitor remotely, and take time-lapse video. Press the "Record" button to start recording video or take a snapshot.
Feb 03, 2013 | Dell inspiron 14r-n4110 laptop intel
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Mar 04, 2011 | Computers & Internet
I can't add arabic language to my computer
How to Install Java in Windows XPProfessional
Java is one of many third-party applications that enhance your experience onyour Microsoft Windows XP Professional operating system. Java, developed by SunMicrosystems, is a programming language and computerplatform that is the backbone behind many of the programs you use today,including games,businessapplications and utilities. Software developers choose the Java platformbecause it has been tried and proven to work the best. Java publishers focus onperformance, stability and security. It's easy to get the latest version ofJava and install it on your XP Professional system.
1. Manually download. Visit the Java site to download the Java application;ensure the version is Windows XP compatible. If you have a 64-bit Windowsoperating system, pay special attention to the download; most Windows usershave 32-bit by default. Save the file to a location that can easily berecalled. 2. Begin installation. Close anyopen Web browsers and applications. Click on the saved Java download file.Click "Run." Read any warnings and agreements. Acknowledgeconfirmations as you proceed, selecting "Next" until eventuallygetting to the "Install" button, and click that as well. 3. Read intermediateinstallation messages. As the main Java application installs, you may encounteradditional advertisements. Read, make decisions, and click the "Next"button to proceed. A "Progress" window will indicate "Status:Installing Java." 4. Verify installation. Afterinstallation is complete, the Java setup window will show "You havesuccessfully installed Java." Click the "Close" button and resumeusing your PC per usual.
5. For additional verification that Java was installed, refer back to theoriginal page from where the application was downloaded. Find the link"Verify Now." Click it to advance the page, and select the red"Verify Java version" button. Wait while the Web page verifies theversion.
TIPS and WARNINGS
After first-time Java installation, the application can be accessed from theWindows XP Professional "Control Panel" on the "StartMenu." After opening the app, click on the "Update" tab toretrieve the most recent version of Java.
It is important to keep Java on Windows XP Professional systems updated forsecurity reasons as vulnerabilities might exist in outdated versions.
Read more: How to Install Java in Windows XP Professional 'eHow.com
Nov 11, 2010 | Microsoft Windows XP Professional for PC
Not found webcam & montherboard after install windows 7
Go to Dell Website http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=25&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=VOS_N_1510&hidos=WLH&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False and download the required drivers for Dell Vostro 1510. Dell Vostro provides only drivers for windows XP and Windows Vista. What you can do is install the Windows Vista Drivers for your Windows 7 and hope it works.
Apr 01, 2010 | Dell Vostro 1510 Motherboard System Board...
What is the purpose of java
high-level programming language developed by Sun Microsystems. Java was originally called OAK, and was designed for handheld devices and set-top boxes. Oak was unsuccessful so in 1995 Sun changed the name to Java and modified the language to take advantage of the burgeoning World Wide Web. Java is an object-oriented language similar to C++, but simplified to eliminate language features that cause common programming errors. Java source code files (files with a .java extension) are compiled into a format called bytecode (files with a .class extension), which can then be executed by a Java interpreter. Compiled Java code can run on most computers because Java interpreters and runtime environments, known as Java Virtual Machines (VMs), exist for most operating systems, including UNIX, the Macintosh OS, and Windows. Bytecode can also be converted directly into machine language instructions by a just-in-time compiler (JIT). Java is a general purpose programming language with a number of features that make the language well suited for use on the World Wide Web. Small Java applications are called Java applets and can be downloaded from a Web server and run on your computer by a Java-compatible Web browser, such as Netscape Navigator or Microsoft Internet Explorer.
Apr 01, 2010 | Computers & Internet
Lately, since we have gotten the internet, and downloaded the required drivers and whatnot our picture doesn't seem to be working. If you go onto youtube and try and watch a video the sound works well but...
Confirm if you have the following applications installed on your PC. But first be sure that the vga driver is installed. The practical way to confirm that the vga is installed is to play a video with a media player application. If during playback the pictures do not hop/break, you know that your vga is installed. Otherwise go to device manager and update your vga driver. To do, this right click on my computer/properties/hardware (xp) then device manager (vista) device manager. Here, look for display adapters. Here you should see a yellow caution sign. Right click on it and select update driver. Mind you, you must be online at the instance.
When that is done and you still are encountering the same problem, download and install the following applications:-
1. flashplayer
2. java (jre-6u15-windows-i586-s)
3. shockwave
Sep 09, 2009 | Dell Computers & Internet
I am using dell vostro 1510 the problem is sound is not clear on my laptop if we run any other application sound get struck is this driver problem ? if yes what the driver i should reinstall
hi
better to reinstall the inbuilt stereo softwares.also you should check your c drive whether it has got the minimum space for the running of the applications.and its better to undergo disk cleanup instantly
Mar 01, 2009 | Dell Vostro 1510 Notebook
What is servlets?
Java Servlet technology provides Web developers with a simple, consistent mechanism for extending the functionality of a Web server and for accessing existing business systems. A servlet can almost be thought of as an applet that runs on the server side--without a face. Java servlets make many Web applications possible.  » Read More The reference implementation is included in the Java EE 5 SDK and also in the open-source Java Platform, Enterprise Edition (Java EE) application server, available through the GlassFish project, which you can download from java.net. The reference implementation source code is available from the servlet-sources project on java.net.
Dec 29, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Vostro 1510 Laptop Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
