Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
My VHS tape won't eject, no matter what I do - Philips Magnavox MWR20V6 DVD Recorder/VCR
  • 734 Answers
Take the top of the case off, then you can remove the tape, manually; after you shut down and removed from the powerline.. Maganavox has tape take up problems, which it needs to power on to eject, after auto shut down.
Posted on Nov 15, 2010
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
I recenly purchased a DV225MG9 A DVD/CD Player with Video Cassette Recorder. After only a few hours of use, the power will not turn on. I now have a VHS cassette that is in the machine and I cannot
1) this a difficult matter since the VHS TAPE is inside.Try to unplugged the EQUIPMENT many times and eject the button for to see if eject the TAPE.
2) put a little of alcohol with a jeringa in switch eject, and try it.
3) if this do not RESOLVE the problem, you take to cut the tape, or dissasembley the section, or go to some repair shop TV for fix it.
Remember unplugged the power cord before to do anything inside of equipment.
You have the option too to call to the supplier and get customer support via online chat for help, or service.
God bless you
Jul 20, 2012 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Hello
Check for any borken drive belt in the mechanism.
Feb 13, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a ION VCR2PC and the power button won't stop blinking. Also when I put a VHS tape in, it turns itself on and then right off again and ejects my tape. There is not anything stuck in the ION...
If the take up spool is not turning properly it is not uncommon for the machine to eject the tape and turn off. Check the drive to that spool and correct.
Sep 08, 2017 | ION Audio VCR2PC VHS VCR
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Tape ejected
check the rubber band on the motor that is used to inserts the tapes. it might be lose or getting old. it does not matter what brand it is, the vcr is programed to take all of them unless there is something worng with the tape. any way, check the rubber band. good luck
Sep 10, 2006 | Toshiba W607 VHS VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
226 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
