Question about Indesit IS70C Electric Dryer
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
Try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Posted on Feb 06, 2011
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Hi i have a two day old beko dcu 7230 tumble dryer the water tank and clean filter light keeps coming on even though they are clean and empty is my product faulty.
not too many dryers w water tank, but the air filter light maybe due to a lack of air movement. If you have replaced an old machine, then your problem may be with the existing exhaust and duct work, you'll need to clean them out thoroughly to know. You may have to go outside or up on the roof as sometimes these also have trap doors that become stuck.
Nov 09, 2013 | Dryers
I have an LG Tromm Front Loader. Recently it has been running full cycles, but after completely draining, it begins to (VERY SLOWLY) fill up with water. For example, I run a load in the morning and by late...
If the drain hose has to rise very high then it is water left in the hose that is coming back in through the one way valve on the pump. If that is not the case, it is the inlet valve that has a bad seat on it and needs replaced.
Nov 04, 2013 | Washing Machines
Whirlpool washing machine WFS 1273 BW keeps coming up with "clean pump" light.Even after i have cleaned pump.Now when I switch machine on sounds like pump is running but no water is coming in and...
Hi.
If you have already cleaned the drain filter in front you may have siphoning. Siphoning means that water is flowing back from the drain hose because of incorrect hose settings. Make sure that the hose is set as from installation manual.
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/ifu/home
Also make sure that you have checked well the drain filter, the one behind the trim at the base in front of the appliance.
Check the drain hose. When there is no blockage at the filter that is usually the cause. If drain hose is not responsible, then parts must be tested. Pump, pressure sensor orcentral control module may be faulty, but that does not happen very ofter.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Oct 05, 2011 | Motorcycles
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Water is coming out of powder draw everywhere and washing machine is not emptying propley
Remove large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Dec 21, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My bosch excel dishwasher has the following fault: start the cycle, water starts to fill but then check water light comes on and it then starts to empty again. Pump then keeps going. I have checked the...
this unit im sure has a water flowmeter that measures the water intake.. if this cannot read then the unit shuts down to avoid flooding..
it needs replacing... it is attached between the valve and the side tank or attached to the tank dependant on model...thanks
Dec 18, 2009 | Bosch Dishwashers
Water will not empty out drum
You need to check the pump filter, if it is not at the lower right front of washer, then remove lower rear cover of washer, remove large black hose fastened to bottom of drum, and remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Nov 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Pre-wash light keeps flashing
The pre wash light flashing is usually an indication that the washer has failed to take in cold water, possibly due to low pressure, or restricted inlet hose.
If it does it when it is the rinse mode, then I would suggest you check the filter is not blocked.
Remove lower rear panel, remove large black hose to bottom of tub
Remove filter inside and clean., check inlet to pump as well.
Plz rate my solution.
Thanks.
Jan 28, 2009 | Washing Machines
Indesit IS70C Electric Dryer Logo
636 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
