Question about Sharp AR-5320 Black and White Copier
Error Code H3 Slove - Sharp AR-5320 Black and White Copier
  • Sharp Expert
  • 255 Answers
Hi, this is a high temperature problem in the fuser unit . It is either caused by defective thermistor or a short circuit in the triac found on the power supply. It can also be caused by power fluctuations during outages.
Solution
Try to clear this code by pressing these keys in this order: #, Interrupt, C, Interrupt. Display must go off. Enter 14 and press Copy key. The code should clear and machine stays in normal status but if it reappears after some minutes, then do the below steps and stop where it works.
  1. Open the fuser unit on the right side of the copier.
  2. Check that the fuser rollers are clean if dirty clean them using alcohol wet cloth.
  3. Check if rollers are worn out and replace.
  4. Check if the thermistor is worn out and replace another one.
  5. Check the power supply and measure if the triac is shorting and replace if it is.
If you do all the above, try to clear the code again as shown in bold. Best wishes.
Posted on Nov 15, 2010
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
What does error h3-00 indicate?
? 1:26
May 5, 2011 - Uploaded by Thomas Trumpler Thomas Trumpler: error code H3-00 I tried this and got to the last step and there was no option using 1 for yes and 2 for no, so I ended up ...
Sep 30, 2015 | Office Equipment & Supplies
Canon ir600 error code E220
sira canon 600 mechan E220 has cmming turn of the power has coming solve the problam how to slove the problam slove it
Jul 17, 2012 | Canon ImageRunner IR600 Copier
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Sharp Z-835 Copier with H3 error code. Your
Hello sir; I don't know which button you are talking about,but follow my steps to reset ; press " clear" , " exposure mode " , "clear " , " exposure mode" those keys , then enter 14 press start. should take care of you. the exposure key is under auto, manual, photo.
Jan 29, 2010 | Sharp Office Equipment & Supplies
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Error H3 00 appears not found in guide book
H3-00 Heat roller high temperature detection
The fusing temperature exceeds 240C°.
Thermistor abnormality.
The easiest and cheapest solution is to replace the fuser.
This is very typical of a laser machine as some point the fuser will go out.
These little machines have a disposal fuser unit. It is possible to replace the parts. After the time and parts, in the long run it is cheaper to replace the whole unit.
Jan 28, 2009 | Sharp FO-DC550 Laser Fax
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
Sharp code h3-00
heat roller high tempareture detection
May 15, 2008 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AR-5320 Black and White Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
