Question about ASUS K50IJ-C1 Notebook
Tach mouse not procces - ASUS K50IJ-C1 Notebook
  • 70 Answers
The problem will be with the driver so check in control panel device manager also try to put a add usb mouse try wether it work with the pc
Posted on Nov 15, 2010
Tach quit working an speedometer goes crazy what would cause
vss has probably gone bad. vehicle speed sensor ( vss)
Apr 24, 2015 | Cars & Trucks
My 1981 corvette tach quite working how do I get working again?
1981 Corvette has an electical tachometer that is driven by impulses from the distributor. First, check for blown fuses, next make sure the tach wire is plugged into the distributor. Next bypass silver tach filter or capacitor located by manifold to see if the tach moves at all. If these steps do not reveal a change in tach operation, then the most obvious next step is to remove the tachometer and get a new board for the tachometer. Unscrew and remove cluster lens and then unscrew tach bezel, and gently pull out the tach noting position of insulators. I believe these boards are available still at local autoparts locations. Replace board, note position of insulators and reinstall tach, bezel and lens. Old corvette are cool and are pretty easy to work on! Should be fixed, enjoy!
Feb 15, 2015 | 1981 Chevrolet Corvette
How to repair or trouble shoot.
The tach itself may be bad. Check with local used parts and get a used one. Should be pretty reasonable to buy the entire dash bezel. Install the entire bezel in your car or carefully remove and replace just the tach
Aug 28, 2014 | 1992 Ford Bronco
My 1997 Dodge Stratus is stuck in limp mode, second gear forward or reverse. It doesn't have a speedometer display or the tachometer most of the time. I replaced the output speed sensor and the Tr
Its not likely the transmission is causing the problem if both the speedo and tach are out. The tach does not involve the transmission.
Sounds more like a problem with the instrument cluster or the body computer.
You may have to get a used shop manual to get the wiring diagrams and testing procedures.
Apr 08, 2013 | 1997 Dodge Stratus
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
Prestige remote start APS-901C on 2007 toyota yaris auto i just installed r/s and tried to program the tach. no response from r/s. led blink twice . no tach or low tach input. checked the wires 5 times...
The tach wire for the 07 Yaris is light green at the data connector under the dash. If you have chosen to go to an injector or coil and, the system responds with low or no tach, go to the tach programming sequence again but, while programming the tach increase the rpm by putting your foot on the accelerator and holding the rpms at 1500 during programming.
Your other option is to program the system for voltage instead of tach. When programmed for voltage, also program for timed output instead of average.
Apr 21, 2011 | Prestige Remote Start
Ignition coil
The tach wire tells the computer information it needs to have engine control.Please rate if this was helpful,thank you.
Jul 19, 2010 | 1990 Chevrolet C1500
Dell Inspiron 1545 laptop keyboard cursor jumps to mouse cursor position while typing
Go to http://support.euro.dell.com/support/index.aspx?c=uk&cs=ukdhs1&l=en&s=dhs
Click the drivers and downloads section.
Enter your service tag number and procced to the download section.
Click Input Device Driver and dowload the alps touchpad exe file. Run this and your problems will be solved.
Oct 15, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
I need sound drivers
my cpu have amd-8151 hypotranspor procces then you tell me which sound drive need in this procces
Mar 28, 2009 | AOpen Computers & Internet
1988 Ferrari 328 gts tachometer quit working.
The Tach is a tricky thing and sometimes just goes out. If all the other lights, etc....work and the tach is connected to the sensor, I suspect the Tach is bad.
Mar 17, 2009 | 1986 Ferrari 328
ASUS K50IJ-C1 Notebook Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
