Question about Remote Start System
My remote control didn't work anymore. there's no light in the remote whenever i press it. Is these a problem of a battery in the remote or something else?
  • Viper Master
  • 625 Answers
If the status light no longer illuminates when pressing the remote (where it did before), the most common reason is a dead battery. If, after changing the battery, the light still fails to illuminate, the problem may be corrosion on the contact points for the battery or, the buttons are not making contact on the circuit board.
Posted on Nov 15, 2010
I forgot my code and whenever i insert battery on my remote the indicator is always on and therby my remote doesnt work
Press power or setup button if indicated light don't turn off make sure you have fresh battery could be a malfunctioning remote
Mar 08, 2016 | Televison & Video
Changed batteries in remote fan still doesnt work hampton bay model uc7083t
If you're gettig a red light whenever you press a button on the handle remote, That means the hand held is working. There are also batteries in the receiver , inside the fan's cowling. They need to be changed too. Also, be sure the wall switch is ON. The remote has no control, if the wall switch is OFF.
Hope this helps and thanks for choosing FixYa.
Jul 28, 2011 | Hampton Bay Heating & Cooling
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Hitachi CLU-5713TSI remote control won't work anymore. Acts like it needs to be programmed again. Press tv button, light comes on then fav channels and snow comes on tv. Can't access anything
Take off the battery, open the back of your remote, lift the circuit board clean the green painted part of the circuit board with cotton balls slightly damp in rubbing alcohol, as well as the black thingy at the back of your remote pad, let it dry put it back together, change with a new battery and see if it works.
Jun 12, 2010 | Hitachi CLU-5713TSI Remote Control
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Problem With Operating the Remote
Check to see that the batteries are installed correct,,may need to reprogram...hope this was helpful...
Apr 23, 2010 | Philips SRU3003 Remote Control
Remote doesnt seem to work on all the button can it be replaced
Did you check the battery of the remote?
Remote is jamp. Take the battery out and put it back. It will help sometime.
Did you notice the light in front of the TV response to remote control whenever you press? If yes, the remote works fine - problem comes from your TV.
Aug 12, 2009 | Televison & Video
Sony av remote
To reset the remote control to the factory default settings, simultaneously press the POWER , TV/VIDEO , and VOL- buttons. Go here for programming instructions; http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMPP412
Sep 03, 2008 | Sony (RM-SP50) Remote Control
HITACHI CLU-5713TSI
Hi i changed the batterys in my remote and now my Hitachi tv that it came with wantwork and every other component that i have. can some one help?
Jul 30, 2008 | Hitachi CLU-5713TSI Remote Control
RCA Universal Remote stopped working
I have the same problem on my RCA UNIVERSAL remote too..any one could me ?
thanks
Jan 08, 2008 | RCA 244889 Remote Control
Remote Start System  Logo
155 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
