Question about HP DesignJet 9000 InkJet Printer
Hi I have a big problem with new printhead konica 256, after installing, my printer HP Designjet 8000s did a test and detects a new print head, I have the following message: ERROR TEMP PH CHECK PH and on the menu information PH MANUFACTURED DATE ????? SERIAL NUMBER ????? RANK?? VOLT USED DATE ????? best regards fethi
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
mayur47
  • 39 Answers
SOURCE: HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Posted on Aug 17, 2009
  • 15 Answers
SOURCE: HP L7680 print head problem
When installing the print heads out of the box you MUST shake them for 30-60 seconds, same goes for ink tanks. If you do not then the lubricant that is added to them will seperate and it will draw thinned out ink causing damage to the print heads. Also, if your system sits for more than a couple weeks (and this goes for ALL printers) then run a test page ence every 2 weeks to keep the system from drying out.
I used to work at a couple office supply stores and this was almost always the issue with bad printheads on HP, Brother and Cannon printers.
Posted on Aug 31, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
Printheads in Designjet 510
Alexander, did you do the allignment after changing print heads?
Feb 01, 2014 | HP "designjet 510 24 in. inkjet printer"
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
Print head
Update your firmware.
Apr 30, 2013 | HP Designjet T1100ps Printer
Hp designjet z2100 keep asking to replace the feed heads of magenta and yellow even after replacement and print block of magenta + yellow.
Try to clean printhead contact , i mean in the arriage not in the printhead, if still asking for printheads , try to enter in digonstic mode " service mode " ,,,, hope help you mohamed hejazi
Apr 01, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Warning (0) clear media jam in hp designjet 8000s
Try cleaning (or blowing air at) the sensor (right hand side near service station)
Dec 21, 2011 | HP Office Equipment & Supplies
Goodmorning, my hp t610 have message print head replacement not complete. I tried several times but the message is always the same. the print head are new!!! I look forward to a response. best...
Hello.
This error occurs when a print head can not be detected. Sometimes the very fine contacts that detect the printhead can become dirty with ink. Power the printer down, remove the heads and try cleaning the circuit contacts on both the printer and the print heads with alcohol wipes. Switch the printer on and replace the heads.
I hope this helps Regards GM
Apr 27, 2011 | HP Designjet T610 InkJet Printer
My Designjet 4000ps is asking to install setup printheads
setup printhead used for priming of ink tube *** to remove the air from tube or blokage it comes with unit when u purchage, pls install them one for each colour then machine performs the test & then u install the new printhead & calibrate the plotor
PLS DONT USE THE OLD PRINT HEADS AFTER PRIMING>>>>>>>>>>>>>>>To keep the device safe
Apr 07, 2010 | HP Designjet 4000ps InkJet Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
HP DesignJet 9000 InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
