Question about Onkyo Audio Players & Recorders
I have an Onkyo A-7055 amd want to hook up two speakers. Looks like a dozen connectors in the back of the unit... which ones to use. If I experiment is there a chance I could blow out the unit?
    Problem Solver:
  • 8 Answers
Do you mean you want to connect 2 pairs of speakers, or just 2 speakers like you say in your question? There are 4 pairs of screws on the back of your amplifier on the upper right side of the rear panel near the fuse cap and the AC outlets. Each pair of screws will be connected to one speaker. Your Onkyo can be connected to 4 speakers. If you want to connect only 2 speakers, use the screws labeled "SPEAKER A" and connect the speakers to the left and right channels, and make sure you connect the + speaker wire to the screw with the red marking around it. Connect your other speakers the same way, one speaker per pair of screws.
Posted on Nov 15, 2010
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
Onkyo ht-r590
I hear all speakers except back ones I took them off in hooked in dif. Spot in heard sound so speakers work ..I went to setup in listen to all speakers no sound from the back
Nov 21, 2011 | Onkyo Audio Players & Recorders
My Onkyo 808 shuts down when i raise the volume, and when I try to set it up using the micophone.
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Dec 09, 2010 | Onkyo TXNR808 Receiver
One channel not working onkyo tx-sr04
You might have to take a look into the unit, there could be some damage or a bad solder connection on the front left speaker connector at the circuit board, possibly also on any other component (power amp chip / transistors, internal connectors, etc.), also loose or broken wires or oxydized connector contacts inside the unit.
It could be something else as well, but i guess it's worth checking the above mentioned.
Hope you can fix it
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Onkyo TX-SR604 Receiver
The receiver thinks there are headphones connected
Onkyo directed me to return the unit to a service center. Apparently this is a known issue and after reading web postings I believe it. There were dozens of similar cases with a variety of Onkyo recievers. I was able to remove the ribon connector from the headphones and discovered it is not a shorted headphone detector. We will see what the service center does. I'm not looking forward to paying for shipping a 66 lb receiver.
Aug 04, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Cutting off and stayin in Stand by mode
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Jun 03, 2008 | Onkyo HT-SR800 System
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
237 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
