Question about Sharp R-963 Convection/Microwave Oven
R-9H66C does not heat.
The table is turning and I hear the fan noise but no magnetron buzz. Could this have to do with the doors contact switchs ? There is a loose in the door and if I pull the door up the table stops but restart when the door is relased but no magnetron buzz and no heat.
  • Sharp Master
  • 9,086 Answers
Yes, it is either a bad door switch or a loose or misaligned door switch holder.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Our Viking VMOS200 just stopped working. The lights and the countdown timer work, but no fan noise and no turntable spin.
it has nothing to do with the magnetron. first you have to fix step one. then you will know if the magnetron is bad. its one or two of the primary switches on the bottom of the switch tower. usually with these mw if you dont press cancel to stop the mw, and you just push the latch to stop it, those wires heat up and cause the microswitches to burn and loose proper contacts.
put a cup of water in the mw. set it to one minute and as its counting down. push on the latch LIGHTLY, as to not fully open the door and you will hear the magnetron kick on and the turn table start to rotate
Mar 06, 2011 | Viking VMOS200 Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave buzz with door closed and off This is a GE JVM1443WR Spacesaver... Microwave works, all buttons work, interior light works, and it will heat food... However, even when the microwave is off and...
You can check the relay and related driving circuit. If there is a short in the relay driving circuit there is chance for this type of problem. or the micro processor may be defective.
May 23, 2009 | Microwave Ovens
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Mar 03, 2009 | Amana Radarange Microwave Oven
My over the stove microwave will run however no heat. Popcorn digets do not count down but set numbers do. odd odor.
Dec 11, 2008 | Microwave Ovens
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Sharp R-963 Convection/Microwave Oven Logo
74 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
