Question about HP 6700
HP DV6700, power keeps switching off after 2-3mins from switch on. Fan does not come on and core temp rises above 90 deg. celcius prior to shutdown. Tried unplugging battery and power then holding power switch for 30 secs then reconnecting...makes no difference. Is the fan faulty which is causing this problem? After cutting out, cannot tun back on for 5-10 mins.
I have the exact same problem...only started 2 days ago...let me know if you find a solution. I wanted to clean it from the inside but you have to take the whole thing apart,and I am not comfortable doing that
Posted on Nov 24, 2010
How do I regulate the temp in the display fridge. It's too cold at 1 deg C
Ideal Temperature is between 34-38 degrees Farenheit. 1 degree celcius converts to 1.8 x 1 + 32 = 33.8. This is ABOVE freezing and should be Perfect...
Oct 21, 2014 | Refrigerators
I ve recently bought an Audi A6,2.7 litre with twin turbo from japan.The problem i ve is, when this car is idling the coolant temp rises to 110 degrees celcius and drops to 90 when its moving.The other...
when stationary their is no air flow through the radiator so temperature will rise and the cooling fan comes on ,now as for it not going off then this could be a sensor ,relay or the computer as the sensor tells the temperature to the computer which turns the fan on and off ,now on these cars the fan will stay on for up to 5 mins after turning the engine off so if after this time it hasnt gone off then consult the dealer as you have bought a asian market software vehicle so it will not respond to a code reader to locate any faults just like the europeon version but the american version can be read with a code reader .
Apr 12, 2012 | 2002 Audi A6
Why does my home heating system comes on then off after five mins
Likely the cause is the plenum switch. The switch is temperature actuated, so the fan does not turn on until the temp rises enough.....so, after shutdown the furnace temp "heat soaks" and the fan will come on and off, sometimes several times, and this is normal.....
Feb 27, 2012 | Heating & Cooling
Acer z5610 suddenly turns OFF Temperature is normal, no overheat, new thermal grease System scanned for errors, viruses - nothing WHAT DOES IT MEAN?
Are you sure the temperatures are ok? When I run DIVX Plus Converter on the Z5610 the CPU (intel Q8200) is running (naturally) at a high load. Speed Fan 4.42 shows rising temperatures going north of 90 degrees C. If only DIVX Converter runs the temperatures of the CPU cores is around 92 to 94 degrees C. But if I start browsing the internet the temperatures go close to 100 degrees C. When one of the cores reaches 100 degrees C Speed Fan shows MINUS temperatures on the cores (-10 to - 20 deg C). Speed Fan is just monitoring as it can not even detect the Fan.
When that happens the Fan stops completely!! And short after that the computer switches of (same as if you would pull the plug).
Obviously there is a bug in the BIOS or the Motherboard which leads to interpretion of temperatures above 100 degrees C as MINUS temperatures which leads to the stop of the fan.
I am sure that also happens whenever you use a CPU intensive program (like a game or any other video converter/rendering program). You might download a temerature monitoring program (i.e. Speed Fan - its free) and see for yourself. Also listen whether the fan stops working compltely (goes completely silent) when the PC overheats and short before it switches off. Let's see what ACER says to that.
I used to like ACER. But first Aspire 4310 tripping frequently because the VGA chip overheats and now that stupid fault ==> never ever ACER again. I will use the Z5610 for internet surfing and get a real all-in-one which you can use. That is a clear sign for me that ACER does not test their machines at all under full load - or knowingly sells faulty machines.
Dec 16, 2010 | Computers & Internet
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
The fan goes on at about 215-217 deg F. The temp. keeps rising up to about 218-219 F while the fan is working and after that the temp. starts dropping down to 215 F and stays there with the fan working....
Hi and welcome to FixYa,
To my understanding, the cooling fan is activated by the ECM. This is done by switching the yellow/black wire to ground. The activation is triggered by the coolant temperature sensor that feeds signals to the ECM. Ideas to consider:
  • verify integrity of connections of coolant temperature sensor (purple/black & purple/green wires) to the ECM;
  • check, clean or replace the coolant temperature sensor itself;
  • bypass ECM and install a manual override switch plus dual reverse protection diode on the 2 yellow/black wires from the cooling fan wire connector.
Good luck and thank you for asking FixYa.
Nov 12, 2009 | 2006 Triumph Daytona 955i
My 94 Tracer temperature gauge reads between 3/4 and 7/8 in the normal range before the radiator fan turns on. I have already replaced the fan temperature switch and the relay. Could my temperature...
Yes, it is possible the temp. sender is faulty, but I would do a cross check of the actual coolant temperature vs gauge reading using a cooking thermometer in the top of the radiator.
Take care not to get scalded - check it at about 180 to 200 deg.
Aug 02, 2009 | 1994 Mercury Tracer
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
1989 mazda rx7 turbo over heating
A couple of ideas you may want to explore:
  • the engine overheating after a shutdown could perhaps be addressed by installing a time delay off on the relay of the radiator fan. The idea is after absence of Ignition B+12 (engine off), the fan/relay should still be energized for a number of minutes so as to cool the radiator;
  • idling the engine for about 5 minutes before shutdown is a good practice. this enable the engine to cool slowly rather than an abrupt change in temperature of the external but the inside is still rather hot;
  • the opening of the thermostat is triggered by the temperature of the water above it not below (where the spring is);
  • in my country, where it is relatively always hot, some mechs remove the thermostat (of course not applicable in cold climates);
  • a more helpful idea would be the installation of an electric water pump in lieu of the mechanical one. There are several after market models. Pls try here, here or here for a start;
  • it is also possible to wire the electric water pump to still run for a minute or more similar to the proposed time delay for the radiator fan above.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 07, 2008 | 1989 Mazda RX-7
Fan keeps running after engine is turned off
why does the cooling fan start working as soon as i start the car and doesn't shut off until i turn off the car?
Oct 05, 2008 | Mitsubishi Lancer Cars & Trucks
HP 6700 Logo
179 people viewed this question
Seeker5211
Seeker5211
